Printer restarts when starting print
ThinLayersDesign
(@thinlayersdesign)
Starting suddenly, no changes, got a good print yesterday, my MK3S just restarts when you select a file to print.  This happens when I am printing from Octoprint or from the SD.  Any ideas?
Postato : 28/10/2019 11:39 pm
RE: Printer restarts when starting print
Usually that's a short in the bed heater.
... or ...
When a user presses RESET [X] instead of OK [knob press].
Postato : 28/10/2019 11:53 pm
ThinLayersDesign
(@thinlayersdesign)
Well a factory reset fixed it
Edit: Or not, I was able to start the printer and do the probing, then it failed
Questo post è stato modificato 6 years fa 2 tempo da ThinLayersDesign
Postato : 28/10/2019 11:57 pm
ThinLayersDesign
(@thinlayersdesign)
@tim-m30
Seems to have been a firmware.  Couldn't have been the reset button since starting from Octoprint did the same thing
Postato : 28/10/2019 11:58 pm
A broken wire in the harness can be intermittent; if the issue continues do an inspection at the bed or you can thoroughly damage things.
Postato : 29/10/2019 12:03 am
ThinLayersDesign
(@thinlayersdesign)
Might be a short in the hotend thermistor/heater. As soon as I try to head the hotend it resets the printer
Postato : 29/10/2019 12:04 am
