Printer reboots on nozzle heat-up
Twisted Zion
(@twisted-zion)
Hi
I've run into a problem. My MK3S reboots as soon as the nozzle starts heating up. (everything else is OK)
This happened after i twisted the nozzle "block" a bit when about to change the nozzle. A short circut maybe? I don't want to mess with it too much as i don't have the enough knowledge. I have a new backup hotend, but was hoping i didn't have to change it. Any tips would be appreciated.
PS: I've checked all of the fuses but no luck.
Posted : 16/05/2021 4:39 pm
Baklin
(@baklin)
RE: Printer reboots on nozzle heat-up
You should measure the resistance of the heater cartridge in the heatend. I think it should be around 14 Ohm.
If you don't have a multimeter (you should really get one for your printer) you can pull the top 5 amp fuse and see if the same happens.
I haven't tried that myself, but without the fuse it shouldn't short out and reboot. Ofcourse it will never heat up and print, but it will get you a step closer to figuring out what the problem is.
Posted : 16/05/2021 4:47 pm
I concur.  There must be a short.  Contact support via chat and will give you steps to confirm it.
Posted : 16/05/2021 4:48 pm
Check that the heater wires are well spaced from the heater block, and not jammed right up against them. And they need to be separated from each other, too.
Use a tooth pick to spread them apart - but careful to not pull them from the cartridge.
Posted : 16/05/2021 7:17 pm
Twisted Zion
(@twisted-zion)
I ended up replacing the hotend as i already had a replacement. This is the third time, i've changed it in two years, so hope this one sticks. Anyway thanks for the replies. I hope Prusa will find a more stable/sturdy solution for future hotends.
Posted : 20/05/2021 2:11 pm
@twisted-zion
When changing nozzles - do not twist the heater block as the Prusa guide says. It will only cause problems.
Posted : 20/05/2021 8:36 pm
Victory Sports
(@victory-sports)
Same exact problem here. Think I even saw a spark when tightening the hotend back. Am I really going to have to change the whole hotend!? Thanks for any other solutions.
Posted : 06/12/2022 9:42 pm
alex
 alex
(@alex-28)
If this happens is there a way to fix it?
Posted : 10/12/2022 1:37 am
Robin
(@robin)
Posted by: @victory-sports
That depends on what's damaged, you can check thermistor and heater with a multimeter (no need to disassemble just unplug on the einsy): https://help.prusa3d.com/ja/article/multimeter-usage_2117
Just replace what is damaged and power down the printer next time before you touch the hot end with metal tools...
Posted : 10/12/2022 11:38 am
Victory Sports
(@victory-sports)
Thanks! Got it fixed. Was the heater cartridge. Feel like I saw to hold the heat block with a wrench in their own literature. Guess i'll try to find a rubber wrench 🤷‍♂️
Posted : 13/12/2022 1:07 am
RandyM9
(@randym9)
The trick is to not touch any wires with metal objects. I know, easier said than done.
If you remove the print fan first, you’ll have better access and visibility to the heater block and nozzle next time.
Cheers
Posted : 13/12/2022 5:06 am
Robin
(@robin)
It’s either that, or just heat it up, cut the power change the nozzle and then power up again..
Posted : 13/12/2022 8:26 am
Hasselbeck
(@hasselbeck)
I've got the same problem! Except I replaced the entire hotend (new block, heatsink, heater cartridge, and thermistor) and it still shorts. If I remove the F2 fuse, that allows the heating sequence to proceed (obviously without heat). The fuse checks out with a multimeter so it's not that. I'm stumped. What else can I check?
Posted : 15/02/2023 9:56 pm
