Printer not powering, lcd flickers.
arik.a
(@arik-a)
My mk3s last night I plugged it in after having it unplugged for awhile as I wasn't using it. I plugged it in to find that it wasn't powering on and the lcd just flickers like its trying to boot up but can't. If I tap the PSU it makes the LCD flicker as well. Is the PSU bad or what could it be and what should I check?
Questa discussione è stata modificata 6 years fa da arik.a
Postato : 30/08/2020 5:41 pm
RE: Printer not powering, lcd flickers.
Posted by: @arik-a
If you have a multimeter, I would check the output voltage (24V) of the power supply. The connectors are located on the Einsy Rambo board. I would also check all fuses.
Postato : 30/08/2020 6:15 pm
