Printer continuously beeps during heating up
Justin A
(@justin-a)
In a past post I highlighted an issue of my creating when changing the nozzle.  I didn't seat it fully and created a leak.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../issue-after-nozzle-change/
After I took the heating components off the printer and cleaned the plastic from them, I reassembled making sure the nozzle was correct.  However when the printer begins it's heating cycle, the printer begins to beep continuously until it just about reaches temperature.  Then it stops for the duration of the print, only to begin with the next print.  I did unplug everything from the mobo that prevented the removal of the heating components to include the heat block and thermister.  The printer has worked fine ever since, I'm just now getting tired of hearing it.
Ideas of what is causing this?
Posted : 01/10/2020 3:37 am
brentonator
(@brentonator)
RE: Printer continuously beeps during heating up
I'm have what sounds like the same problem. @justin-a-2 Did you ever figure out a solution?
This post was modified 5 years ago by brentonator
Posted : 30/01/2021 9:26 pm
brentonator
(@brentonator)
I just found out that my problem was caused by being connected to the batter backup outlet on an APC UPS.
Posted : 31/01/2021 4:36 am
