print triggers smoke detector
hello everyone, today a jop went extremely wrong. in the middle of the first layer everything burned up. i printed petg at 220 degrees as usual. i have absolutely no idea how this could happen, are there any ideas or suggestions here where the error was?
RE: print triggers smoke detector
possibly your thermistor came loose!,
maybe the mosfet which controls the heater went short circuit!
were there any screen messages?
I don't remember a message on the screen, I pressed reset too fast. the possibilities you mention sound permanent, but the printer is still working and just doing its job again as intended.
