Print removal with larger metal tool can cause display to blank, flicker back after a few seconds
David H. Brown
(@david-h-brown)
Having started with a Mk2 and similar non-removable bed printers, I've been in the habit of removing prints (once the bed has cooled) using a broad (6"/150mm) drywall joint knife (I've filed the corners round) and continue to do so when bending the sheet doesn't work (small ASA parts stick too well). Just got a Mk3S+ (kit) and I noticed that when I do this, sometimes the LCD will blank out for a few seconds and eventually flicker back in.
It's not pressure pinching a wire somewhere; it has to be a metal tool of sufficient size (probably beyond what Prusa had in mind by "spatula with rounded corners") and it seems like I have to go pretty much all the way across within about half a second. While doing much the same, I had never observed this screen blanking on my Mk2 (upgraded to 2.5, 2.5S).
I unplugged the printer and removed the heat bed connector cover so I could check it out with an oscilloscope. Sure enough, when I do this, I can measure a spike of at least +/-3V between the heat bed screws, presumably caused by induction when moving the metal across the copper foil "coils" of the print bed. (Looks a little bit like what you get if you forget the clamping diodes around a relay.)
I'm presuming this isn't good for the circuitry, so I will simply be trying to retrain myself not do that as the most expedient solution. But I thought I would share this information / experience in case anyone has additional thoughts or is experiencing the same without recognizing the (hopefully small) potential to damage the board.
https://www.printables.com/@DavidHBrown_24313https://www.thingiverse.com/davidhbrown/designs
Opublikowany : 11/01/2022 11:19 pm
Helmuth
(@helmuth)
Interesting troubleshooting
I'm genuinely impressed at how you did the troubleshooting here.
It's never really occurred to me to leave the steel sheet on the magnetic bed when removing a print, it just seems safer to avoid applying force to the heated bed.
Opublikowany : 13/01/2022 7:39 am
