					                		Print job continued for 5 hours after what I presume is yet another hot end clog - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/print-job-continued-for-5-hours-after-what-i-presume-is-yet-another-hot-end-clog/</link>
                <lastBuildDate>Sun, 10 May 2026 23:35:12 +0000</lastBuildDate>
                        <title>RE: Print job continued for 5 hours after what I presume is yet another hot end clog</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/print-job-continued-for-5-hours-after-what-i-presume-is-yet-another-hot-end-clog/#post-667840</link>
                        <pubDate>Mon, 07 Aug 2023 20:23:29 +0000</pubDate>
                        <description><![CDATA[Thanks for the good advice!]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the good advice!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Scryptic</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/print-job-continued-for-5-hours-after-what-i-presume-is-yet-another-hot-end-clog/#post-667840</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/print-job-continued-for-5-hours-after-what-i-presume-is-yet-another-hot-end-clog/#post-667821</link>
                        <pubDate>Mon, 07 Aug 2023 18:55:47 +0000</pubDate>
                        <description><![CDATA[Clean out the gears and the filament path, cold-pull to remove any clinker.The two common reasons - if nothing else has been touched - are damp filament, some filaments change surface qualit...]]></description>
                        <content:encoded><![CDATA[<p>Clean out the gears and the filament path, cold-pull to remove any clinker.</p><p>The two common reasons - if nothing else has been touched - are damp filament, some filaments change surface quality when damp and can begin to slip, and filament diameter: if you change to a filament with a slightly smaller diameter - measured, don't trust the adverts; then it too can slip.</p><p>Dirt or dust on the spool can get into the works and cause problems ...</p><p>and if there is excessive build up of dust around the Bondtech gears they may clog and loose grip.</p><blockquote><p>Does it not have a way to know that it isn't feeding filament?</p></blockquote><p>That depends where the problem is - often not.  The older style of sensor was more capable at this but failed with certain colours.</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/print-job-continued-for-5-hours-after-what-i-presume-is-yet-another-hot-end-clog/#post-667821</guid>
                        <title>Print job continued for 5 hours after what I presume is yet another hot end clog</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/print-job-continued-for-5-hours-after-what-i-presume-is-yet-another-hot-end-clog/#post-667805</link>
                        <pubDate>Mon, 07 Aug 2023 16:57:58 +0000</pubDate>
                        <description><![CDATA[About a month or so ago, I had my first hot end clog. I had a few hundred hours of printing in. Last one was the Lack Enclosure.I learned how to fix that, and printed about maybe another hun...]]></description>
                        <content:encoded><![CDATA[<p>About a month or so ago, I had my first hot end clog. I had a few hundred hours of printing in. Last one was the Lack Enclosure.</p><p>I learned how to fix that, and printed about maybe another hundred hours and midway through a long print (again) it stopped feeding filament, but continued to pretend to print, just no filament came out.</p><p>I was able to heat up the hot end to about 10c over the normal petg temps, and pull the filament out. it had a bit of extra filament on the end.</p><p>With subsequent reheating, I can't get any filament to load, just the grinding noise. I'll be taking it apart again to clean out the hot end.</p><p>Two Questions regarding this:</p><p>1.) Why did it keep printing even though no filament was being run through the nozzle? Does it not have a way to know that it isn't feeding filament?</p><p>2,) Why would I get another clogged hot end, or whatever it is again so soon? </p><p>This is why I gave away my Ender 3 Pro and spent the money and time to purchase and build the kit. I was expecting rock solid reliability.</p><p>Any education, tips, guidance, etc will be appreciated, waiting to clean out the hotend until I read something helpful. Maybe I need to do something else when it clean the hot end so I can get several hundred more hours before this happens again.</p><p>I3s+<br />Prusament PETG<br />Factory nozzle that came with the printer (.40)<br />Sliced to .15 for better detail.<br />OctoPrint<br />Printer is in a closed Lack Enclosure, no extra ventilation. <br />20% infill.</p><p>Thanks smart folks.</p><p>-= bruce</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/print-job-continued-for-5-hours-after-what-i-presume-is-yet-another-hot-end-clog/#post-667805</guid>
