Print Gone Wrong Caused Wire Disconnect
Hi there,
Printer MK3S
Filament: PLA
So I was printing a long print that normally has no issues but this time the filament did not stick to the bed causing a glob of plastic around the nozzle. I was able to remove the glob for the most part but it caused some of the wires to become disconnected (see images below). I am unsure which wires were fully damaged and would appreciate any advice and help identifying the wires damaged and where to start for fixing this.
Zoomed out nozzle and wires
Up close wires
Thank you all.
Publié : 28/12/2023 6:11 pm
