Preventive maintenance screws up PINDA
G Bell
(@g-bell)
I have an i3 MK3S which is a year old and has been printing great!  I decided to do some preventive maintenance and went through the list on the Prusa site.  I tightened every bolt and screw, including all those on the back of the hot end.  Full cleaning and lubrication of rods.  I opened up the Einsy-case and tightened all the screws.  I found that the Y belt was a bit loose and tightened it up.
The problems started when I ran the Z Calibration.  The second calibration point the nozzle didn't stop and went all the way against the print bed.  The PINDA had not triggered.  Strange, I thought.  I lowered the PINDA by a tiny amount and reran the Z calibration.  Now it goes past the second calibration point but does the same thing on the 9th and final calibration point.  I checked the PINDA sensor and it read 0, even with the nozzle against the bed.  But it seemed flaky and would go to 1 if I moved the PINDA at all.  Also it only seems flaky when the hot end is at the top right (last calibration point).
I tested the PINDA by putting a screwdriver up against it and it seems fine.  No flakiness observed.  But this is with the hotend in the middle.
I am looking for suggestions on what I might have done.  My first idea is that tightening all the bolts on the back of the hot end was not a good idea.  This might have pinched the cable from the PINDA.  Second idea is that there is a partial break in the PINDA cable, anywhere along its length.  Third idea is that by opening up the Einsy-case I somehow messed up the PINDA connection.  I will open it up again and check the connection.
Any ideas on what the problem might be?
Ce sujet a été modifié il y a 6 years 2 fois par G Bell
Publié : 17/09/2020 2:50 pm
G Bell
(@g-bell)
RE: Preventive maintenance screws up PINDA
I should mention that I lowered the PINDA to the same level as the nozzle and the printer passed the Z-calibration.  But I still think there is a problem, I don't think the printer should be run with the PINDA this low.
Publié : 17/09/2020 3:56 pm
G Bell
(@g-bell)
A quick update on my printer, in case anyone else has a similar issue.  It seems to be OK now, I believe the issue was a pinched wire in the PINDA at the back of the hotend.  I checked the connection of the PINDA to the EINSY board, and it was fine.  I took off the back of the hot end, I didn't notice any pinched wires but I reattached it less tightly.
The printer then passed Z calibration after I lowered the PINDA.  Whereas before I was running with a Z adjust of -0.5 now it is -1.5.  This seems a bit odd, but it seems to be working fine now.
Publié : 19/09/2020 11:33 pm
Swiss_Cheese
(@swiss_cheese)
glad I read the last post I was going to suggest it may be a short, same thing can happen with the LCD , fan wires, thermistor wires etc,, sometimes it requires a replacment. eventually some of those components wires will wear and need replacement, so far its mostly been fan and thermistor for me but I keep extra PINDA's around also.
Having to re-adjust Z is not odd at all after a good checkup and screw tightening its normal that it might be different.
Glad you got things going again
Enjoy
The Filament Whisperer
Publié : 21/09/2020 12:13 am
