[Solved] Possible firmware bug for MK3S
CapnMal
(@capnmal)
I'm having thermal runaway errors occur on large prints at consistently the same location within the print. Small prints seem to work fine. Large prints not. For example; extruder set point is 250 but the actual temperature will change from 250 to around 235 at a consistent point in the print; however, the setpoint is still 250. Consequently, the feedback algorithm can never achieve the 250 temperature and throws a thermal runaway error. I have verified this behavior with MK3S firmware 3.9.0 and 3.9.1. Also, the behavior is present with and without Octoprint. I have printed off of SD card and same thing happens. I have checked the GCODE file and nothing pops out. Again, I must reiterate that the print seems to behave as it should up to a certain point. I have printed the same part 3 times and the error consistently occurs at the same location in the print. So, a hardware issue can be eliminated as the cause. It's either a firmware issue or a PrusaSlicer issue. Please help!
Posted : 17/10/2020 11:38 pm
Area51
(@area51)
RE: Possible firmware bug for MK3S
Photos tell more than thousand words...
Many thermal runaway errors is typical caused by broken wires to thermistor or heating element. A broken wire can be hard to detect as it only fails when it is bend the right way. Part cooling fan is another source of runaway as it can trigger a runaway at high to full speed.
At the firmware level bad PID regulation setup can can give over/under shoot of temperature. Try running a PID configuration on the printer in firmware to calibrate the hotend PID around 250C.
Posted : 18/10/2020 1:04 am
CapnMal
(@capnmal)
Area51, thanks for replying . You bring up an interesting point regarding the PID calibration.  I'll have to dig into that. I have a hard time believing it's a bad wire or thermistor issue since the error occurs at EXACTLY the same point in the print 3 times in a row. A hardware issue should be more sporadic than that.  That said, I'll check the resistance of the thermistor and look for loss of continuity in the wiring.
Posted : 18/10/2020 2:59 am
CapnMal
(@capnmal)
OK, I've run the PID calibration routine.  That was successful.  The thermistor resistance is a bit low if it's supposed to be 100 k Ohms as I've seen elsewhere on this forum.  It's hovering between 75-80 k Ohms.  Anyone think that's my problem?
Posted : 18/10/2020 5:34 pm
CapnMal
(@capnmal)
ADDENDUM: Possible firmware bug for MK3S
More information....I took the thermistor out of the system completely and measured it's resistance.  Out of the printer, it initially read 130 k Ohms but depending on how I hold it and the wires entering the thermistor, it would drop to ~100 k Ohms.  I tried this on another spare thermistor I have and it does the same thing.  Is this normal for a thermistor?  Shouldn't it be a constant 100 k Ohms regardless of how it's held or how the wires are oriented?  In any case, I've ordered some new thermistors.
This post was modified 5 years ago by CapnMal
Posted : 18/10/2020 6:13 pm
Hi Wayne,
A thermistor is specifically designed to change resistance significantly as the temperature changes.
so it sounds like it's doing the right thing.
I believe the 100K ohm value is expected at a thremistor temperature of 25Centigrade.
So if you are holding the thermistor bead / cartridge, it is reasonable for the temperature to be higher than 25C and therefore the resistance to be below 100Kohms...
Different manufacturers have different temperature response curves for their thermistors,  so it's always a good idea to get one from the same company as the manufacturer of your printer uses. Which for Prusa, I believe is Semitec...
Posted : 18/10/2020 7:45 pm
CapnMal
(@capnmal)
Thanks Joantabb!  I'm still going to install a brand new thermistor just to absolutely eliminate that variable.  Do you or anyone know how to verify the heater cartridge operation?  Should it have a specific resistance as well?  That's the only other hardware item I can think of that might cause my thermal runaway error.
Posted : 18/10/2020 8:10 pm
Posted : 18/10/2020 8:17 pm
Hi Wayne,
24 volt 40 watt heater, should measure about 14 ohms when cold, the resistance will increase slightly when it heats but not a lot...
Be careful not to get a 12 volt heater (about 3.5 ohms cold), that would bee bad news  it would try to draw 160 watts...
Regards Joan
Posted : 18/10/2020 8:31 pm
CapnMal
(@capnmal)
Thanks Tim and Joan!  Much appreciate the help.
W
Posted : 18/10/2020 8:33 pm
Area51
(@area51)
Posted by: @wayne-h
Don't touch the wires while measuring the thermistor resistance as your body/fingers will be part of the measurement. If untouched the measured value should be around 100k and be constant if temperature is constant.
As @joantabb points out it is important to get the same type/make as the original as they measure differently. It also has to be one of the high temperature ones used by E3D and Prusa.
Posted : 19/10/2020 12:02 am
CapnMal
(@capnmal)
OK, problem solved!  Turns out it wasn't a hardware or firmware issue.  It was a user problem!  When I sliced the part in Prusaslicer, I had the bridging fan speed set to 100%.  So........when my extruder is trying to maintain 250C and a bunch of air is being blown across it, it can't keep up with the heat loss and eventually declares a thermal runaway error.
It's always the little things.
Thanks for the help anyway.
Wayne
Posted : 22/10/2020 12:14 pm
Get yourself a silicon sock to go around the heatblock.  e3d ones last longer.  Then run the pid again as now its will have a nice warm coat 🙂  Gets rid of all that temperature drop.  I dont run printers without them now and I think they should come as standard.
Posted : 22/10/2020 1:23 pm
CapnMal
(@capnmal)
@neophyl
Good idea.  I'm on it.
W
Posted : 22/10/2020 1:37 pm
