PID eeprom
Hey guys. I have 3 newbie questions.
1. How can I restore the eeprom to factory default?!
2. In prusaslicer printer settings- custom gcode you can add everything you want. Making that changes the config file from the eeprom?!
3. If I save some pid values to eeprom....choosing a profile from prusaslicer with some different pid values.....which values will be in the prints?!
thanx.
RE: PID eeprom
- Factory reset instructions here.
- You don't save the start gcode (or any other gcode) to the printer. It is inserted into the gcode generated by the slicer.
- The value last set on the printer will remain in effect until changed or the printer is reset or power cycled.
RE: PID eeprom
@bobstro
Thanx a lot my friend.
By my mistake I save to eeprom thought octaprint some pid values. But I prefer to put values and make profiles to prusaslicer. It is more easier and practical.
Do you know how to delete only the pid values in config file that I save without loosing all the calibration of the printer?!
RE: PID eeprom
but I didn't understand what you saying. which is the value last se on the printer?! the eeprom or the start gcode on prusaslicer?!
