PID AutoTune
If I set the temp for 250C and do PID Autotune. Is that good enough for PLA at 215C?
I print PETG at 250C but not too often, mainly PLA.
Thanks
Posted : 02/07/2021 9:34 pm
RE: PID AutoTune
It's recommended to do PID tune at the temperature you use most often. Accuracy at other temps will vary from that somewhat, so you want the most stable temp to be the one you use most. It doesn't have to be super accurate, so those values will work at other temps, but it may take a bit longer for temps to stabilize.
Posted : 02/07/2021 10:06 pm
