Pausing between Objects (not layers)
Plugs
(@plugs-2)
Folks in SLicer I see we have the option to put code to be executed between objects.  I have a First Later test that prints 3 squares 12mmX12mm in a diagonal across the print bed. I use this so I can tweak the Z height between each square and it helps hugely fine tuning Z level. What I would like is that as Im printing 3 objects that it stops after each one so I can inspect the results and easily put in a new value for the next. I have tried M601 as in the layer pause but it doesn't stop.
I am hugely ignorant of G-Codes so any help would be appreciated.
Postato : 27/07/2022 9:10 pm
https://help.prusa3d.com/en/article/prusa-specific-g-codes_112173
Postato : 28/07/2022 12:19 am
Ringarn67
(@ringarn67)
Mine does, see attached file
However, in THIS particular print with the settings and filament I used second part just build up a blob on the nozzle.
Maybe I should have check nozzle before starting second part, and/or clean sheet, who knows 🤔
Back to your question, the printer pause between objects!
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Postato : 28/07/2022 11:07 am
Plugs
(@plugs-2)
RE: Pausing between Objects (not layers)
I know RTFM has its place and I had already read up on M601 but its not working. Providing 3MF like below is more helpful.
Postato : 29/07/2022 10:25 am
Plugs
(@plugs-2)
Ringarn I first tried adding your code in between objects
;BETWEEN_OBJECTS
M601
That didn't work so then tried your 3mf and changed it to Mk3 Printer and nozzle at 0.25 as the only changes and it didn't stop. I wonder if there is something else I have to do for Custom G-Code to be recognised
Just looked at the g-code output and if I am reading correctly its commented out. I presume ; is a G-code comment
; between_objects_gcode = ;BETWEEN_OBJECTS\nM601
Postato : 29/07/2022 10:36 am
Plugs
(@plugs-2)
Uncommenting that line in gcode itself has zero impact
Postato : 29/07/2022 11:01 am
Ringarn67
(@ringarn67)
Sorry for being away...
The line you commented out is at the end of file is from settings..
Could you please save, zip and upload your 3mf- file where you have problems
Postato : 30/07/2022 7:42 pm
