Pause ok - Resume not heating extruder
Pressed pause last night to take picture of object, z lift & x home ok. Pressed resume and display showed bed stable at 60deg but extruded temp dropping. Waited 10 minutes but extruder still going down. Eventually aborted and started again.
Any thoughts ?
Re: Pause ok - Resume not heating extruder
Guess its safe to day it didnt work....
I believe this has been reported to the develoopers.
Do you keep up to date with firmware revisions.
Next time you need to take a photo. You could try slowing the print down on the lcd and take your photo when the extruder is in the best ppsition.or
you could initiate filament change take yoir photo,, remove and reinstall the fillament and then continue the print.
Regards Joan
Thanks, firmware up to date. I can always pause etc from s3d but not likely to use this function very often.
