Partially lost pinda temperature calibration can someone post theirs?
Punkgeek
(@punkgeek)
Hi ya'll,
So I inadvertently selected the pinda auto temperature calibration feature (which is experimental). Alas, it didn't work because of this issue: https://github.com/prusa3d/Prusa-Firmware/issues/798
So I figured no worries, I'll wait till the issue is fixed someday. Alas though, I just noticed that this tool clobbered my factory default configuration for the pinda temp offsets (for all the temperatures after the points where the tool failed). I'd like to get those standard defaults back 😉 (though my printer is printing fine).
So if you haven't run this busted tool would you mind posting the results of "M861 ?" on your mk3? They should look something like this:
Recv: PINDA cal status: 0
Recv: index, temp, ustep, um
Recv: n/a, 35, 0, 0.00
Recv: 0, 40, 29, 72.50
Recv: 1, 45, 41, 102.50
Recv: 2, 50, 49, 122.50
Recv: 3, 55, 0, 0.00
Recv: 4, 60, 0, 0.00
Recv: ok
Opublikowany : 08/08/2018 6:56 am
