					                		PA+CF filament blocking - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/</link>
                <lastBuildDate>Sat, 09 May 2026 16:44:20 +0000</lastBuildDate>
                        <title>RE: PA+CF filament blocking</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616905</link>
                        <pubDate>Thu, 11 Aug 2022 06:39:35 +0000</pubDate>
                        <description><![CDATA[I have solved the clogging issue. I have dried the filament (overnight, at about 50 degrees C) and the print completed successfully. Good to know. Jan]]></description>
                        <content:encoded><![CDATA[<p>I have solved the clogging issue. I have dried the filament (overnight, at about 50 degrees C) and the print completed successfully. Good to know.</p><p> </p><p>Jan </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JanK</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616905</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616698</link>
                        <pubDate>Tue, 09 Aug 2022 12:28:53 +0000</pubDate>
                        <description><![CDATA[I was assuming you were printing from a drybox, nylon is extremely hydroscopic and a couple of hours exposure is enough for troubletwo standard fixes for a filled material clogging are a lar...]]></description>
                        <content:encoded><![CDATA[<p>I was assuming you were printing from a drybox, nylon is extremely hydroscopic and a couple of hours exposure is enough for trouble.</p><p>https://help.prusa3d.com/materials</p><p>The two standard fixes for a filled material clogging are a larger nozzle and try a few degrees hotter.</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616698</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616683</link>
                        <pubDate>Tue, 09 Aug 2022 09:47:25 +0000</pubDate>
                        <description><![CDATA[No, 0.6mm is the largest I have.One idea I got today was that it could be because of a wet filament, although it was stored properly. I will try to dry it. Jan]]></description>
                        <content:encoded><![CDATA[<p>No, 0.6mm is the largest I have.</p><p>One idea I got today was that it could be because of a wet filament, although it was stored properly. I will try to dry it.</p><p> </p><p>Jan</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616683</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616647</link>
                        <pubDate>Tue, 09 Aug 2022 02:13:03 +0000</pubDate>
                        <description><![CDATA[Do you have a 0.8mm nozzle to try?Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>Do you have a 0.8mm nozzle to try?</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616647</guid>
                        <title>PA+CF filament blocking</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616622</link>
                        <pubDate>Mon, 08 Aug 2022 21:53:13 +0000</pubDate>
                        <description><![CDATA[Good evening. I have Prusa MK3S, about 2 years old, which works fine. I have succesfully printed many objects using PLA, PETG, ASA, Nylon, PP, PC, FLEX... However, I have difficulties printi...]]></description>
                        <content:encoded><![CDATA[<p>Good evening. I have Prusa MK3S, about 2 years old, which works fine. I have succesfully printed many objects using PLA, PETG, ASA, Nylon, PP, PC, FLEX... However, I have difficulties printing with the Spectrum PA6+CF15 (nylon+carbon fiber) filament. I am using the hardened steel M6 nozzle. The printing starts fine but after some time (e.g. 30  minutes), the filament is blocked and stops flowing. To unload it, I need to open the extruder and remove the filament manually, since the filament is deformed by the extruder wheels and they can no longer get a good grip. I have tried increasing the temperature, reducing the speed, increasing the flow rate, loosening and tightening the extruder screw, switching off retraction, changing the spool holder and other things but I did not succeed. The same nozzle prints fine with other filaments such as PETG. Smaller objects print fine with the same filament  (nylon+carbon). </p><p>Any idea where the problem might be?</p><p>Jan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/pacf-filament-blocking/#post-616622</guid>
