Out-of-Range Resistance
Ryan
 Ryan
(@ryan-6)
I've had to dismantle two shared printers due to bad clogs, one of which was caused by a bent (??) heat break and I had to melt out the clog.
I fixed those issues, but before putting everything back together, I tested the red heat block cables with a multimeter and got a high reading of 16 ohms, where 15.1 is supposed to be the highest. The other printer was even higher at 19 ohms.
Are these readings problematic? What issues might I face if I continue to use the machines? Should I replace both heat blocks?
Posted : 09/05/2020 5:12 am
