Original Prusa Drivers & Apps - 2.2.0
Página 2 / 3
Pathogen
(@pathogen)
Re: Original Prusa Drivers & Apps - 2.1.8
I found out about this update after I ran Slic3r the other day and it said there was new profile update but no matter what I tried it wouldn't actually update, so I decided to uninstall the entire Prusa software suite, but there was no new release on github but oddly there was a new version inside the latest official package release. Installing all 2.2.0 package solves the original Slic3r issue for me. Everything seems to be working so far! :ugeek:
Respondido : 04/09/2018 9:31 am
JPWhitestar
(@jpwhitestar)
Re: Original Prusa Drivers & Apps - 2.2.0
Ok, my problem was not with software but with my FlashAir. I need to figure out why I can write to it but not read via WiFi.
Respondido : 04/09/2018 10:16 pm
emotionalvampire
(@emotionalvampire)
Im having the problem with the driver file downloading and upon running saying its corrupt. Tried under IE and Edge and had the same problem. Strangely though any driver package prior to 2.1.6 downloads and installs correctly, 2.1.7 and 2.1.8 say corrupt
In case of browser issue, I tried in Google Chrome and did notice that the file downloads all the way near to the end but then shows 'Failed - Network Error'. Tried a couple of times and same error at the same place.
Finally I tried via the TOR browser, which takes an extremely long time due to the nature of its network and after download, the file worked perfectly fine.
Hope this helps someone
Respondido : 04/09/2018 10:37 pm
mnl1121
(@mnl1121)
Hi all, I'm also having a problem downloading DRIVERS & APPS 2.2.0. It fails out with a network error towards the end.
Respondido : 05/09/2018 5:28 pm
brice.h
(@brice-h)
I'm having the same issue when trying to install prusa3d_win_2_2_0.exe in Windows 10. Any suggestions? I've tried on two different PCs.
Brice
Respondido : 06/09/2018 2:45 pm
emotionalvampire
(@emotionalvampire)
Both the above posts, are the same as what I was getting.
Like I said, my solution was to use TOR. Google TOR PROJECT for more info and download the browser.
Respondido : 07/09/2018 9:05 am
brice.h
(@brice-h)
Hi Darryl,
Thanks for the suggestion. I really don't want to install a separate browser. Seems like Prusa needs to provide a better solution for downloading their software package.
Brice
Respondido : 07/09/2018 11:01 am
my downloads failed with Google chrome, but worked with Firefox.
I understand that Firefox is the browser under the TOR skin....
at least that is what barclays said when their help desk asked me to try different browsers... chrome failed, microsoft edge failed, TOR was successful. then the next day barclays put my account into fraud, because I had used different browsers... they claimed someone had successfully accessed my account using firefox....
they restored my online banking after I made a complaint, but left telephone banking blocked for 6 months....
I don't get on, with Barclays!
Respondido : 07/09/2018 12:53 pm
brice.h
(@brice-h)
Thanks for the suggestion about Firefox. I started up a VM and downloaded it installer on that via Firefox.
As a general rule, I don't like installing seperate browsers to download a single file. The web team at Prusa needs to find a better solution for downloading their installers.
Brice
Respondido : 07/09/2018 1:54 pm
Hi Brice
I try to always have two non microsoft browsers on every computer. In case is browser hijack...
Joan
Respondido : 07/09/2018 2:12 pm
Steve_AU
(@steve_au)
The issue is that the download is stalling before it is finished. This will be an issue with the webserver/host, not the browsers. Because of this, the issue will vary between browsers (one day, IE, next Firefox).
I used wget for windows (command line program), any other extension or program which supports resuming downloads will work just as well.
Respondido : 09/09/2018 6:30 am
Patrick.b
(@patrick-b)
Hi Brice
Joan
Hi Joan
sorry can't find right post so , i reply here .
Any setting for the Prusa Flex in Slic3r or Prusa control ? like the PRusa PLA or PET .....can't find Prusa Flex ? can we load an .ini files tested by Prusa . as the other one . so easy and knowing that work already 😉 😀
some update or ?
Thanks
BR
Respondido : 09/09/2018 12:24 pm
kreedaz
(@kreedaz)
Using previous suggestions of other posters, I installed firefox and downloaded with that.
As Stephen.P suggested:
The download did terminate abruptly, but Firefox was able to restart and complete the download once I clicked on the failed download in the downloads status box in Firefox.
Install on Win 10 worked flawlessly now that I had a complete file.
Respondido : 22/09/2018 9:20 pm
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
Regarding the issues with the downloads thanks for the feedback, I've noticed this myself. However, it doesn't fail every time, so we are still tracking the issue.
Assembly manuals
/ Knowledge Base
Respondido : 09/10/2018 10:39 pm
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
Any setting for the Prusa Flex in Slic3r or Prusa control ? like the PRusa PLA or PET .....can't find Prusa Flex ?...
the ini file includes "ColorFabb nGen" flex and "SemiFlex or Flexfill 98A", more here https://github.com/prusa3d/Slic3r-settings/blob/master/live/PrusaResearch/0.2.5.ini I asked our Material Grand Master to tell me more about the Flex, will let you know 😉
Assembly manuals
/ Knowledge Base
Respondido : 09/10/2018 10:50 pm
Patrick.b
(@patrick-b)
Thanks Jakub
I did some tst and set up many parameter since , i have relativ good result so far, just still have some oozing or string but not easy with Flex filament..and big problem is , as i set up under Print setting - retraction - length = 5.5mm , i have problem on filament stuck into the extruder... 😡 so need pause , open and replace ..
after a while is ok i realze the tension on the filament is important too..
Respondido : 10/10/2018 1:39 pm
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
More info regarding Flex from our Grand Master:
The most common flex filaments we have a great experience with is SemiFlex and Flexfill. General profile for Flex is almost impossible as each Flex needs a specific set of parameters.
Assembly manuals
/ Knowledge Base
Respondido : 10/10/2018 2:24 pm
Yoshi
(@yoshi)
when I try to install the software I get the following error. I'm running Win10 on a Macbook Pro in Bootcamp. PrusaControl installs without any problems. I tried installing the previous version, but had the same problem.
Respondido : 11/10/2018 10:03 am
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
Hi Yoshi,
can you specify the build of the Windows? We will test it.
Assembly manuals
/ Knowledge Base
Respondido : 11/10/2018 1:58 pm
Yoshi
(@yoshi)
Hi Yoshi,
thanks! build 17134.285
Respondido : 15/10/2018 10:27 pm
Página 2 / 3
