On the fence
mike-4
(@mike-4)
On the fence
I am a proud owner of Taz 4 and have been printing for ~5 years now. I’m no expert but not green either.  I’ve been really impressed with the Prusa printers and am considering buying an MK3S kit.   I’m trying to get a sense of (a) is it worth it and (b) how much will I need to learn/relearn.   (Honestly though I’m pretty sure A is yes and B is what it’s all about anyway.  That’s the fun).  Guess I’m trying to gauge how much skills and/or parts are transferable.   I know the filament size is different so there’s that.  I use openscad mostly for modeling but that’s upstream.   I mainly use Cura as the slicer which I’m sure I can use for prusa but I believe the recommendation is to use Prusas custom slicr.  I use octoprint to control and monitor.   What am I missing?   Has anyone made the leap from Taz to MKs?   What’s been your experience?
Posted : 16/09/2019 9:34 pm
RE: On the fence
Hi Mike,
as a seasoned printer you should find the switch easy.
design workstream is pretty much the same
slicers ...   every one has a favourite...   many folk use Cura with the Mk3.
Prusa slicer 2.1 has some nice features, give it a try!
Joan
Posted : 17/09/2019 12:07 am
rmm200
(@rmm200)
RE: On the fence
There are also Prusa configuration files available for Cura. That makes the transition a bit easier.
The only thing I use Cura now is for tree supports. It is nice to have a variety of tools available.
Posted : 17/09/2019 1:08 am
K7ZPJ
(@k7zpj)
RE: On the fence
Hi Mike,
I have both a TAZ5 and a MK3S with the MMU2S.   The TAZ is a very capable printer and unless there is something you want to do that it can't then there isn't much reason to  buy another printer.    I bought the MK3S due to its ability to do multi-color prints that you can't do on the TAZ.  (Plus, I just wanted to buy a new printer).
The MK3 has a lot of nice to have features such as mesh bed leveling, power panic, removable build sheets  and the filament sensor.  But in reality they are a nice to have feature and some of those features may still need a little work.
Prusa Slicer is easy to learn so that shouldn't be reason to not to get a MK3S.    I use Cura LE for the TAZ and Prusa Slicer for the MK3s/MMU2. Octoprint is easy to setup for the MK3S and Prusa slicer can send gcode to Octoprint just like Cura.
Overall buying the MK3S with the MMU2 has been a positive experience for me.  It took some time to work out the kinks with the MMU and color printing but I have it dialed in and working well now.   I was worried about the TAZ sitting idle collecting dust after I started using the MK3 but that didn't happen. The TAZ5 is still busy.
Regards,
Bruce (K7ZPJ on the Lulzbot forum)
Posted : 17/09/2019 1:54 am
mike-4
(@mike-4)
RE: On the fence
@bruce-p4
Thanks for the feedback.  I fear It’s a little bit of “the grass is always greener” type thing and that as you said there really isn’t a substantial reason.    This forum post is part self-convincing and part getting to know community (forum lulzbot is a great resource and fun).
I think my primary reasons are:
  • it’s something new.  I’ve had my Taz for 5 years now.   Still capable machine but hey it’s a comfy old shoe at this point
  • - I enjoy 3D printing but my experience has been limited to the Taz 4.   Having never even tried another printer I’m curious
  • auto level!
  • finer 1.75 filament prints
  • Faster and quieter prints
I’m intrigued by removable build sheets and the filament sensor but don’t fully appreciate the benefits of these features yet
Anyway  - as with all hobbies   Better clubs don’t make you a better player   But they still call to you
Thanks again!
Posted : 18/09/2019 1:16 am
RE: On the fence
I've used my filament sensor a few times ... but it is usually OFF.  Too many false alarms when it is enabled.  The MK3S supposedly fixed many of the failings, but I read a lot of posts here and there is a background hum the MK3S sensor still has its issues.
Removable sheets are useful.  But I've been using the same side of one for years... a new sheet is waiting, but still don't "need it" ... lol.
Faster might be relative. If you think you are getting 200 mm/s print speeds, the truth is closer to 60 mm/s and less.  The MK3 can lay down infill pretty fast, but 200 mm/s ?  Consider that non-print moves are set by Prusa to 180 mm/s ... so why they allow 200 mm/s for a print speed makes me wonder.
But I understand seeing those new shoes in the window.
Posted : 18/09/2019 3:08 am
