Nozzle drives into build plate really hard.
RE: Nozzle drives into build plate really hard.
Hi Skelator,
Is the Pinda hanging in free space to the right hand side of your build plate when this problem happens?
if this is the case the Pinda cannot sense the build plate because it has missed the build plate.
you need to look to see why the pinda has missed the build plate.
chances are that something has prevented the extruder from homing properly to the left hand side of the X axis, when the printer started it's mesh bed levelling.
are there any obstructions? if there are, please correct them.
does the printer X axis assembly slide smoothly from side to side?
Did you lubricate the linear bearings during assemble?
If not, now might be a good time to do some maintenance, and Lubricate the smooth rods...
https://help.prusa3d.com/en/guide/lubrication-tips_23200
