					                		Noise from the power supply - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/</link>
                <lastBuildDate>Fri, 12 Jun 2026 04:42:22 +0000</lastBuildDate>
                        <title>RE: Noise from the power supply</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-619358</link>
                        <pubDate>Tue, 06 Sep 2022 17:34:46 +0000</pubDate>
                        <description><![CDATA[mine sounds identical.  Please post if you have problems with it.]]></description>
                        <content:encoded><![CDATA[<p>mine sounds identical.  Please post if you have problems with it.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Robin</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-619358</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-616839</link>
                        <pubDate>Wed, 10 Aug 2022 15:43:10 +0000</pubDate>
                        <description><![CDATA[I hadn&#039;t noticed it before, but mine appears to make the same sound.  It is not at all loud: easily drowned out by.... anything]]></description>
                        <content:encoded><![CDATA[<p>I hadn't noticed it before, but mine appears to make the same sound.  It is not at all loud: easily drowned out by.... anything</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JimB</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-616839</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-616813</link>
                        <pubDate>Wed, 10 Aug 2022 12:50:48 +0000</pubDate>
                        <content:encoded><![CDATA[<p>https://youtu.be/ZDwzrx357bA</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JosefLoukota</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-616813</guid>
                        <title>Noise from the power supply</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-616811</link>
                        <pubDate>Wed, 10 Aug 2022 12:42:38 +0000</pubDate>
                        <description><![CDATA[Since the build, the power supply on my printer has been making a loud noise. The noise starts as soon as the printer is turned on and can be heard all the way through the run time. I am con...]]></description>
                        <content:encoded><![CDATA[<p>Since the build, the power supply on my printer has been making a loud noise. The noise starts as soon as the printer is turned on and can be heard all the way through the run time. I am concerned about a faulty power supply, damage to the printer, or burnout. Support has told me that this sound is normal. Please does anyone have the same experience?</p><p>I am attaching a video which shows that both fans are not moving and the sound is indeed coming from the power supply.</p><p></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/noise-from-the-power-supply/#post-616811</guid>
