No sorting since the maximum number of files in a folder has reached 100
prusanewuser
(@prusanewuser)
Hi, I am using i3MK3S+. When I inserted a SD card to the machine, it says that there is no sorting since the maximum number of files in a folder has reached 100. The file which I just created did not show up at the top on the screen. Why there is such a limitation? Can we overwrite it?
Best Answer by Neophyl:
Use folders. The mk3 unlike some printers can access files in sub folders. Keep your files organised and remember the more you have in a list the longer it takes to read and sort through.
Posted : 17/09/2023 3:24 pm
Hello
(@hello)
RE: No sorting since the maximum number of files in a folder has reached 100
Posted by: @prusanewuser
Id like to see that no you carnt over write it 8 bit boards only have so much power so things like this need to be limited
Posted : 17/09/2023 7:36 pm
Posted : 17/09/2023 7:39 pm
prusanewuser
(@prusanewuser)
Thank you
Posted : 17/09/2023 9:12 pm
