New Raspberyy Pi Zero 2 W
GuyH
 GuyH
(@guyh)
There's a new Pi Zero with the same form factor.  Immediately I thought of using it with one of my MK3S.
https://www.raspberrypi.com/products/raspberry-pi-zero-2-w/
Posted : 28/10/2021 7:29 am
Lichtjaeger
(@lichtjaeger)
You should ask Gina Häußge first to make sure it is compatible with Octoprint. Because the Zero 1 W was not.
Posted : 28/10/2021 7:36 am
GuyH
 GuyH
(@guyh)
It works
Just seen on Twitter that Gina confirms it works!  It should work with the MK3S although she recommends a separate PSU.
Posted : 28/10/2021 9:28 am
endorsed
Yup - endorsed by octoprint.
Posted : 28/10/2021 9:57 am
GuyH
 GuyH
(@guyh)
I've ordered 2.  I've a Mk3S+MMU2s that I may try it with.
Posted : 28/10/2021 2:23 pm
Pins
I really wish they would release a RaspberryPi Zero 2 WH.
Posted : 28/10/2021 2:36 pm
k3213
(@k3213)
WH
At least this PL shop sells them: https://kamami.pl/raspberry-pi-zero-2/587963-raspberry-pi-zero-2-wh-z-512mb-ram-4x1ghz-wifi-bluetooth.html
Posted by: @cwbullet
Posted : 28/10/2021 2:55 pm
Power is going to trip up a lot of projects
Posted by: @guyh
I expect we're going to see a lot of installs where it "works just fine" until you run into a power hungry RPi mid-print. Still, it was inevitable that an improved Zero was released. Glad to see it. Now to wait a couple of months to see if Microcenter offers them in-store for $5.
Posted : 28/10/2021 3:03 pm
k3213
(@k3213)
DVFS?
You could likely downclock CPU (lock on DVFS). This should do the trick.
Posted by: @bobstro
Posted by: @guyh
Posted : 28/10/2021 3:07 pm
Pins
I agree.  I am going to wait for a price drop and the pre-soldered pins.
Posted by: @bobstro
Posted by: @guyh
Posted : 28/10/2021 3:08 pm
