[Solved] New Printer will not get beyond guided setup screen.
Smoot
(@smoot)
Hi all. I just unboxed my new printer. I updated firmware and drivers as per the start guide. I removed all zip ties and foam as well. When I turn on the printer, select my language, and am directed to the Y/N question of being taken through a guided setup, I run into issues. If I select Yes, or No, the fans start to spin for a few seconds, but then cut off and the screen returns to the Y/N selection. Any assistance would be appreciated.
Posted : 06/11/2020 5:50 pm
RE: New Printer will not get beyond guided setup screen.
You aren’t pushing the X button are you to answer the question ?  That’s the printer reset button, the enter button is to push the encoder down.
Posted : 06/11/2020 6:20 pm
Smoot
(@smoot)
@neophyl
I am extremely embarrassed that is exactly what I was doing. It wasn't readily apparent that the dial is actually also a button. Thank you for  the response.
Posted : 06/11/2020 7:16 pm
vintagepc
(@vintagepc)
You weren't the first, and you won't be the last... 😉
Posted : 06/11/2020 7:24 pm
Ditto -- I fought that design flaw for quite a while myself.
Posted : 06/11/2020 9:35 pm
