New printer stuck in loop
Gamero
(@gamero)
I have a new printer, MK3S+ Kit, just assembled it, and installed the firmware.
I get the message "Hi, I am your original Prusa i3 printer. Would you like me to guide you through the setup process? Yes/No"
If i select Yes (or No), it says "sorting files" and a progress bar. When that is complete, it returns to the welcome message mentioned above.
Please help.
Napsal : 17/02/2021 9:52 pm
RE: New printer stuck in loop
Posted by: @gamero
Please help.
Hello and welcome to the Prusaforum!
As a first step, I would perform a factory reset and then reinstall the firmware via the actual PrusaSlicer:
https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_9_3_MK3S.zip
Napsal : 17/02/2021 10:15 pm
egar
 egar
(@egar)
I seem to remember having a similar thing happen to me when I first setup my printer.  When you selected Yes or No, how did you indicate the selection?  Did you push the knob (black knob in the photo) or the X below it?
If you pushed the X, that's the printer reset and it will start the whole process over again.  To acknowledge the selection, press the center of the knob.
This post was modified před 4 years by egar
Napsal : 17/02/2021 11:00 pm
hli
 hli
(@hli)
"Sorting files" indicates an inserted SD card. Is there one? If so, remove it and try again (and then it might be worth a bug report for the firmware).
Napsal : 17/02/2021 11:27 pm
1 lidem se líbí
