momentary stutter on x and y axis only in one direction
Ritzy
(@ritzy)
I noticed I was getting some layer shift and in inspecting the printer; when I run a belt test, the x and y axis both stutter for just a moment at the midpoint of their travel and this only happens in one direction. Any ideas? belt values are 241 and 283. Thanks.
Publié : 01/12/2020 4:13 am
Ritzy
(@ritzy)
RE: momentary stutter on x and y axis only in one direction
as it turns out, this is normal for the belt test. so i'll continue hunting down my other issues elsewhere.
Publié : 01/12/2020 6:37 am
@ritzy
Hi Ritzy,
did you Lube the linear bearings?
can you check that the rear cover on the X axis is not too tight, misaligning the bearings,
Can you check that the Y axis ubolts are not too tight
Publié : 01/12/2020 11:25 am
