MK3S+ with MMU3 and the Filament Bar
Hi everyone,
i thought i give it a try here after all i have tried now but this "problem" is driving me crazy.
First of all the Printer itself runs smooth with the MMU3 and gives good print results IF the startup sequence runs through without this
Filament sensor bar that runs through the display. in 99% of all printstarts i have to cut the tip of the filament because the printer thinks there is
some sort of issue and throws a "-" on the last digit instead of a full block. i have a Mini and a Voron 2.4 which makes the same filament tips but
start printing right away. Is there any possible way that the printer doesnt make this startup check and eats the filament "as it is"?
greets
Napsal : 30/05/2025 3:06 pm
