MK3S Thermal Anomaly on Firmware 3.13.2
Seite 1 / 2
sinicide
(@sinicide)
I just updated my Prusa MK3S (stock, no modification) to 3.13.2 and I'm running into Thermal Anomaly failure message. I went ahead and did the PID calibration that completed and it looked like it was saving the settings. Then I proceed to try and unload filament, but then I'm hit with the Thermal Anomaly error.
Snippets I pulled from Octoprint when viewing the messages
Recv: PID Autotune finished! Put the last Kp, Ki and Kd constants from above into Configuration.h
Recv: T:209.9 /210.0 B:48.2 /0.0 T0:209.9 /210.0 @:127 B@:0 P:30.0 A:34.1
Recv: LCD status changed
Recv: echo:enqueing "M301 P27.02 I2.63 D69.31"
Recv: echo:enqueing "M500"
Recv: ok p:27.02 i:2.63 d:69.31
Recv: echo:Settings Stored
Recv: T:208.7 /0.0 B:48.0 /0.0 T0:208.7 /0.0 @:0 B@:0 P:29.9 A:33.9
Recv: T:207.5 /0.0 B:48.0 /0.0 T0:207.5 /0.0 @:0 B@:0 P:30.0 A:34.0
Recv: T:204.9 /0.0 B:47.9 /0.0 T0:204.9 /0.0 @:0 B@:0 P:29.9 A:33.9
Recv: T:201.7 /0.0 B:47.7 /0.0 T0:201.7 /0.0 @:0 B@:0 P:30.1 A:34.0
Recv: TM: error |2.290413|>1.200000
Recv: TM: error triggered!
Recv: // action:cancel
Cancelling on request of the printer...
Recv: echo:Printer stopped due to errors. Supervision required.
Recv: tmc2130_home_enter(axes_mask=0x04)
Recv: TM: error |2.117927|>1.200000
Recv: TM: error |2.003180|>1.200000
Recv: T:214.8 /0.0 B:47.5 /0.0 T0:214.8 /0.0 @:0 B@:0 P:30.1 A:33.9
Recv: TM: error |1.808180|>1.200000
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x04
Recv: TM: error |1.710491|>1.200000
Recv: TM: error cleared
Recv: TM: error |1.541211|>1.200000
Recv: TM: error |1.409958|>1.200000
Recv: TM: error |1.305300|>1.200000
Recv: echo:busy: paused for user
Recv: TM: error |1.274363|>1.200000
As you can see the PID Autotune finishes, and then it stores the value and that looks to be fine, but then I get an ERROR triggered. Not sure what's up. I was originally on 3.11.0 where it was working fine, but I believe 3.12 introduced the Thermal Safety stuff.
Any ideas on what's up or what more to gather to troubleshoot this?
I was reading on the Thermal Calibration documentation and see possible codes for temp model debugging, but I don't think I need to do that since the PID Calibration finished without error. Is my MK3S too old that I just need to disable Thermal model protection? Or do I just need to downgrade firmware? Please note I bought my MK3S back in 2019, so maybe my MK3S is missing something the newer ones had?
Veröffentlicht : 04/12/2023 10:28 pm
Leon
 Leon
(@leon-5)
RE: MK3S Thermal Anomaly on Firmware 3.13.2
Did you redo the Thermal Calibration after the PID?
Veröffentlicht : 05/12/2023 12:59 pm
sinicide
(@sinicide)
Yes, I tried the Thermal Calibration, that fails during the calibration process. This is from after a cold boot up.
Recv: TM: cool down <50C
Recv: echo:busy: processing
Recv: T:229.0 /0.0 B:26.5 /0.0 T0:229.0 /0.0 @:66 B@:0 P:32.6 A:28.6
Recv: T:228.1 /0.0 B:26.7 /0.0 T0:228.1 /0.0 @:0 B@:0 P:32.7 A:28.1
Recv: T:225.1 /0.0 B:26.8 /0.0 T0:225.1 /0.0 @:0 B@:0 P:32.7 A:28.2
Recv: T:221.8 /0.0 B:26.8 /0.0 T0:221.8 /0.0 @:0 B@:0 P:32.7 A:28.1
Recv: T:217.1 /0.0 B:26.8 /0.0 T0:217.1 /0.0 @:0 B@:0 P:32.7 A:28.1
Recv: T:212.9 /0.0 B:26.9 /0.0 T0:212.9 /0.0 @:0 B@:0 P:32.7 A:28.2
Recv: T:208.3 /0.0 B:27.0 /0.0 T0:208.3 /0.0 @:0 B@:0 P:32.7 A:28.1
Recv: T:203.1 /0.0 B:26.9 /0.0 T0:203.1 /0.0 @:0 B@:0 P:32.7 A:28.2
Recv: TM: error |2.011728|>1.200000
Recv: TM: refine C est.
Recv: TM: calibr. failed!
Recv: echo:Thermal Model settings:
Recv: echo:  M310 I0 R16.58
Recv: echo:  M310 I1 R18.40
Recv: echo:  M310 I2 R16.70
Recv: echo:  M310 I3 R15.20
Recv: echo:  M310 I4 R14.10
Recv: echo:  M310 I5 R13.30
Recv: echo:  M310 I6 R12.70
Recv: echo:  M310 I7 R12.10
Recv: echo:  M310 I8 R11.70
Recv: echo:  M310 I9 R11.30
Recv: echo:  M310 I10 R11.00
Recv: echo:  M310 I11 R10.80
Recv: echo:  M310 I12 R10.60
Recv: echo:  M310 I13 R10.40
Recv: echo:  M310 I14 R10.20
Recv: echo:  M310 I15 R10.10
Recv: echo:  M310 P38.00 U0.0000 V1.00 C14.47 D0.0650 L2160 S1 B0 E1.74 W1.20 T-7.00
Recv: TM: error |1.887417|>1.200000
Recv: T:215.7 /0.0 B:26.9 /0.0 T0:215.7 /0.0 @:0 B@:0 P:32.8 A:28.1
Recv: T:210.5 /0.0 B:27.0 /0.0 T0:210.5 /0.0 @:0 B@:0 P:32.7 A:28.2
It heats the nozzle up to 230c then tries to cool down below 50c, but then encounters an error and aborts. When I tried to recalibrate again, it fails during the heat up to 230c.
Recv: TM: initial C est.
Recv: T:48.5 /230.0 B:25.2 /0.0 T0:48.5 /230.0 @:127 B@:0 P:27.8 A:30.5
Recv: T:49.6 /230.0 B:25.2 /0.0 T0:49.6 /230.0 @:127 B@:0 P:27.5 A:30.4
Recv: T:52.1 /230.0 B:25.3 /0.0 T0:52.1 /230.0 @:127 B@:0 P:27.4 A:29.7
Recv: T:57.1 /230.0 B:25.3 /0.0 T0:57.1 /230.0 @:127 B@:0 P:27.7 A:30.0
Recv: T:62.6 /230.0 B:25.2 /0.0 T0:62.6 /230.0 @:127 B@:0 P:27.5 A:30.2
Recv: T:68.6 /230.0 B:25.3 /0.0 T0:68.6 /230.0 @:127 B@:0 P:27.7 A:30.4
Recv: T:74.7 /230.0 B:25.3 /0.0 T0:74.7 /230.0 @:127 B@:0 P:27.6 A:30.5
Recv: T:81.1 /230.0 B:25.5 /0.0 T0:81.1 /230.0 @:127 B@:0 P:27.5 A:30.4
Recv: T:87.3 /230.0 B:25.3 /0.0 T0:87.3 /230.0 @:127 B@:0 P:27.5 A:30.2
Recv: T:93.5 /230.0 B:25.2 /0.0 T0:93.5 /230.0 @:127 B@:0 P:27.8 A:30.2
Recv: T:99.5 /230.0 B:25.5 /0.0 T0:99.5 /230.0 @:127 B@:0 P:27.7 A:30.7
Recv: T:105.6 /230.0 B:25.5 /0.0 T0:105.6 /230.0 @:127 B@:0 P:27.5 A:30.9
Recv: T:111.6 /230.0 B:25.3 /0.0 T0:111.6 /230.0 @:127 B@:0 P:27.9 A:30.6
Recv: T:117.5 /230.0 B:25.2 /0.0 T0:117.5 /230.0 @:127 B@:0 P:27.9 A:30.9
Recv: T:123.1 /230.0 B:25.4 /0.0 T0:123.1 /230.0 @:127 B@:0 P:28.3 A:31.1
Recv: T:128.6 /230.0 B:25.6 /0.0 T0:128.6 /230.0 @:127 B@:0 P:28.1 A:30.9
Recv: echo:  M310 I0 R20.50
Recv: echo:  M310 P38.00 U0.0000 V1.00 C12.10 D0.0650 L2160 S1 B0 E1.74 W1.20 T-7.00
Recv: TM: error |-2.303012|>1.200000
Veröffentlicht : 05/12/2023 2:18 pm
It might be helpful if you do a full factory reset and then recalibrate the printer.
wbr,
Karl
Veröffentlicht : 05/12/2023 4:42 pm
sinicide
(@sinicide)
I would like to avoid full factory reset and leave that as a last resort as I don't want to have to manually redo the first layer calibration again. How can I get more information on the error that the printer's encountering?
Like what are the values being compared here? What is the negative value here from? what is the 1.2 value specifying? In some of the instances I see that the value is indeed non-negative and larger than 1.2, but again I don't know what that value is supposed to be in reference to. If I know where this is from it might help me to investigate further.
Veröffentlicht : 05/12/2023 4:55 pm
HeliosX
(@heliosx)
Mitglied
Same issue here. I tried all now. I can't print. Always thermal anomaly. 🙁
Veröffentlicht : 07/12/2023 8:29 pm
Eliot Lytle
(@eliot-lytle)
We have quite a few Prusa MK3S+ printers here and all were updated to the new firmware with no issues.... except one that had a "Thermal Anomaly." After a lot of digging around, and almost taking the Thermistor apart etc., I first tried backing up to Firmware 3.11 and have had no issues since. Our plan here is as we encounter this issue, reset the factory data and then back up to Firmware 3.11.
What you describe above is exactly what we encountered but what's funny is no other machines have had a "Thermal Anomaly" issue yet. At a loss as to how some will have this issue and some won't.
Veröffentlicht : 08/12/2023 9:54 pm
Staphon Arnold
(@staphon-arnold)
Mitglied
Curious about when the errors started for everyone. I've had my firmware updated for a few weeks now, lots of successful prints, but then I'm just now getting all of the errors.
Anyone else printing good for a while and then having this issue? or was it apparent right when you updated?
Veröffentlicht : 19/01/2024 4:48 am
Daniel Marinescu
(@daniel-marinescu)
Mitglied
I have a different problem,  the Thermal Calibration finishes successfuly but when i preheat or print Thermal Anomaly appears on the screen and it makes some loud beeps but it continues to heat up and i can print, it works ok but it's kind of annoying
Diese r Beitrag wurde geändert Vor 2 years von Daniel Marinescu
Veröffentlicht : 19/01/2024 7:51 pm
Daniel Marinescu
(@daniel-marinescu)
Mitglied
Recv: T:38.25 E:0 B:22.2
Recv: TM: error |0.864550|>0.850000
Recv: TM: error |0.924357|>0.850000
Recv: T:41.5 /215.0 B:22.4 /60.0 T0:41.5 /215.0 @:127 B@:127 P:0.0 A:29.9
Recv: TM: error |0.894785|>0.850000
Recv: T:42.78 E:0 B:22.7
Recv: TM: error |0.897194|>0.850000
Recv: TM: error |0.927984|>0.850000
Recv: TM: error |0.991097|>0.850000
Recv: T:48.98 E:0 B:22.7
Recv: TM: error |0.972216|>0.850000
Recv: TM: error |0.949638|>0.850000
Recv: T:51.7 /215.0 B:22.2 /60.0 T0:51.7 /215.0 @:127 B@:127 P:0.0 A:30.4
Recv: TM: error |0.932488|>0.850000
Recv: TM: error |0.886612|>0.850000
Recv: T:54.24 E:0 B:22.3
Recv: TM: error |0.895253|>0.850000
Recv: TM: error |0.869563|>0.850000
Recv: TM: error |0.874880|>0.850000
Recv: T:58.48 E:0 B:21.8
Recv: TM: error |0.884780|>0.850000
these are the errors i have
Veröffentlicht : 19/01/2024 11:00 pm
Robin_13
(@robin_13)
I upgrade firmware when it came out and didn't have any thermal anomaly warnings until this week.  Hadn't printed with PLA for months and was doing some PLA prints and kept getting errors during the first few layers of the print.  I print in an enclosure but had the doors open for the PLA.  No real drafts to affect the print.  May do a thermal calibration again.
I even had a thermal anomaly while doing a PET pre-heat today.  At least it doesn't stop the print.  Going to retry the calibration.
Veröffentlicht : 20/01/2024 8:06 am
Daniel Marinescu
(@daniel-marinescu)
Mitglied
now it's random, or might be because of the ambient temperature, today before sunset i didn't have any errors, now it started to have TM error again.
Veröffentlicht : 20/01/2024 9:08 pm
Ryan Patterson
(@ryan-patterson)
Mitglied
Just encounter this exact thermal anomaly after good prints. My wife suggested maybe it's just dusty. I obliged the idea and she was right. A little bit of compressed air and it started working.
Veröffentlicht : 24/06/2024 6:40 pm
Allen8355
(@allen8355)
I get "Thermal Anomaly" with 3.13.3 on a MK3S+ and 40W Revo.  It beeps and complains, but doesn't stop printing.
Veröffentlicht : 24/06/2024 10:55 pm
Richdesr
(@richdesr)
Mitglied
I have a MK3s+ that I had installed the MMU 2 on. After dealing with frustrating issues regarding the MMU I finally de-modified my printer, ie. removed the MMU, put every thing back the way it was before installing the MMU using the build manual. Have tried updating the firmware from 3.11 to 3.13 with no luck.  Every time I update from Prusa slicer I get a message that says flash successful, but when I try to do a Thermal Calibration I get two or three loud beeps and the message that the print has stopped. I have done this three times. I roll back to 3.11 and printer works fine.  I just replaced the hot end assy due to another issue with a Prusa hot end.
Veröffentlicht : 26/06/2024 3:12 pm
sinicide
(@sinicide)
For anyone else finding this old thread, in my situation it turned out my Thermistor was bad, this was advised by Prusa Support to replace it, I bought a replacement and replaced it in my MK3S and it resolved the issue with newer firmware.
Veröffentlicht : 27/06/2024 1:53 am
Sheehanhandcrafted
(@sheehanhandcrafted)
Mitglied
I was advised by Prusa support to get a replacement Thermistor. While waiting on the part to be delivered I reinstalled the previous software and everything is working fine🤷🏻 I will probably put the new thermistor in when it arrives and then try the updated firmware again.
Veröffentlicht : 29/06/2024 2:24 pm
Sparker5016
(@sparker5016)
It's 2024 and I've been working with the E3D people for days.  NO success.  Thermal Anomaly.  When you go back to 3.11, smooth as silk.  They can't fix it.
Veröffentlicht : 08/07/2024 9:04 pm
Sparker5016
(@sparker5016)
What I can understand is why isn't the thermistor bad in ver 3.11 firmware?  How does it fix itself?
Veröffentlicht : 08/07/2024 9:07 pm
Allen8355
(@allen8355)
The thermal model Prusa implemented in 3.13 does not work. The best solution is just to turn it off. Search for "turn off thermal model."  You just need to send some GCODE and problem solved.
Veröffentlicht : 16/07/2024 5:14 am
Seite 1 / 2
