MK3S Firmware upgrade wiped out my sheet profiles.
David O
(@david-o-2)
I have updated firmware to 3.10 and my sheet settings vanished. There is no longer any option to select sheet profile. It is so long since I needed to adjust the profiles that I began to believe I had forgotten where the settings were. It is going to be really inconvenient to go through the HW settings calibration every time I switch sheets. I am assuming that all the profiles are lost even if I downgrade the firmware?
Posted : 12/05/2021 10:13 am
Baklin
(@baklin)
RE: MK3S Firmware upgrade wiped out my sheet profiles.
No problems here after updating to 3.10.
Try flashing again.
Posted : 12/05/2021 10:39 am
@baklin
Same here. Everything was back where it was supposed to be.
Posted : 12/05/2021 11:24 am
Ditto - but I have to admit when I did review the new menus, the sheet selector seemed in a different - less convenient - place: but it was there.
ps: as for loss of data. If flashing did corrupt EEPROM data, it is gone and reverting will not help. And IF it was corrupted, then a factory reset with a full data clear (erase the EEPROM completely) is the best way forward.
This post was modified 4 years ago by --
Posted : 12/05/2021 4:57 pm
I will check the menus.  I did not notice the last 2-3 days.
Posted : 12/05/2021 6:42 pm
