MK3S 3.9.0 compiled firmware does not match Prusa release
ANTALIFE
(@antalife)
As title says, compiled firmware from 3.9.0 git branch (MK3_3.9.0) does not match Prusa release
I tried compiling on Windows 10 but had issues like other people. So I installed Fedora 5.7.14-200 on my laptop and followed the Linux compile instructions from Prusa. I seem to compile without any issues, but when I compare the size (and contents) of my hex file to the one from Prusa the two are different (see below for files). Could anyone tell me how this can be?
Sample files: https://drive.google.com/drive/folders/1QXONciumbPcrTrNbyJ1rokzDtNl7zqIO
Github issue: https://github.com/prusa3d/Prusa-Firmware/issues/2799
www.antalife.com
Posted : 12/08/2020 12:27 pm
vintagepc
(@vintagepc)
RE: MK3S 3.9.0 compiled firmware does not match Prusa release
the official firmware also contains language data for non-English .
While possible to assemble locally it's an extra step that doesn't happen if you follow the standard build instructions.
Posted : 12/08/2020 1:34 pm
ANTALIFE
(@antalife)
@vintagepc
Yup, when I compile I also produced hex files for a bunch of other languages. But the one I am comparing is for ENG
www.antalife.com
Posted : 12/08/2020 9:13 pm
jsw
 jsw
(@jsw)
Having been involved in many software development projects over the decades, I can say that it's very common for intermediate files (.hex, etc.) and executable files that have been built on different platforms, and even on the same platform at different times, to differ.  There are so many variables in the process.
Posted : 13/08/2020 8:07 am
ANTALIFE
(@antalife)
@jsw
Hmm, I would understand if it was only the timestamp that was different, but with me there is way too much ?_?
Again I don't see any unexpected errors during compile (see "Fedora-terminal.txt"), but there seems way too much different. Plus when I upload my FW ("My-firmware.hex") to printer a few options become disabled, like spool join which shows as N/A
https://drive.google.com/drive/folders/1TPdhWBeQHGp1Y5BMv2ibwR_NSoT-6x5e?usp=sharing
www.antalife.com
Posted : 13/08/2020 10:01 am
vintagepc
(@vintagepc)
Posted by: @jsw
hex files are not "intermediate", the are the final executable binary for the target platform. Unless you have differing compiler configurations (optimizations etc), they should be identical regardless of the machine it was built on, excepting "baked-in" things like the date/time the firmware was compiled or the host's name.
Posted : 13/08/2020 1:52 pm
towlerg
(@towlerg)
The problem with hex format is that a small change will generate apparently wildly different output. Are you sure you are comparing like with like eg. debug mode, newer external libraries and other stuff I can think of now)
Posted : 14/08/2020 4:06 am
jsw
 jsw
(@jsw)
Posted by: @vintagepc
Posted by: @jsw
We may have to agree to disagree here.  🙂 I've done a lot of low-level machine control stuff over the decades and I know of countless cases where things like module link order, compiler and linker switches, word/page/etc. alignment, etc. will cause identically-working executables to differ considerably when compared.
Posted : 14/08/2020 6:40 am
ANTALIFE
(@antalife)
Posted by: @jsw
Posted by: @jsw
Yea I think you are spot on here. After quite a bit of discussion with 3d-gussner on GitHub, the closest I can get it to Prusa's hex is:
The different lines are:
:1072C000553253004E4F4D4B3353002E01417567DD
:1072D000203133203230323000436F6D70696C657D
:1072F0006C7420636F6E6669672900417567203181
:107300003320323032302032313A31333A3539009D
:109450002E2073656E736F7220762E3A0041756709
:109460002031332032303230004533447636667551
:10966000008813000010101020FFFFFFFF4D37305F
:10000000A55AB44BF6256D01000073636D01000025
:1025F000656E69205A00A55AB44BB62B6D010000D8
:1026000065646D010000EA023C034D035D03640351
:1051B000852A6D01000073656D010000EA02360367
:107C300000A55AB44B8A2C6D01000072666D0100DC
:107C400000EA023603460356035C0362037503B57C
:10A8C0002B6D01000074696D010000EA023503463A
:10D3C000A55AB44B27286D0100006C706D01000058
Which translates to:
�rÀU2SNOMK3S.�AugÝ�rÐ 13 2020Compile}�rðlt config)Aug 1��s3 2020 21:13:59���P. sensor v.:Aug �� 13 2020E3Dv6fuQ������� ÿÿÿÿM70_�¥Z´Kö%m�scm�%�%ðeni Z¥Z´K¶+m�Ø�&edm�ê�<�M�]�d�Q�Q°�*m�sem�ê�6�g�|0¥Z´K�,m�rfm�Ü�|@ê�6�F�V�\�b�u�µ|�¨À+m�tim�ê�5�F:�ÓÀ¥Z´K'(m�lpm�X
Also what really helped is compiling with "./PF-build.sh" instead of "./build.sh" like the Prusa Linux instructions say
www.antalife.com
Posted : 14/08/2020 8:51 am
