mintemp error, can't resolve
cneilson73
(@cneilson73)
Hi all,
I have a MK3S and had a failed print which made a mess of the extruder and had a mintemp error.
So I ordered 2 new complete hot ends as I wanted a spare. Removed the old hot end replaced with a brand assembly but still getting the mintemp error. 0 degrees on the screen which doesn't move.
What I've done:
* Upgraded to the latest 3.9.0 firmware.
* Tried plugging in both brand new hotends.
* Double checked I was plugging into the correct electrical slot on the board.
* Checked the electrical pins in the board, they look good.
* Tried jiggling the wires, display doesn't move from 0 degrees
* Inserted the new hot end thermistor into the bed thermistor electrical slot, this checked out OK as the "mintemp bed" error resolved itself.
* The red/black wires were reversed on the new thermistor plug. Tried swapping them around and verified it was OK using the bed thermistor slot. Seems polarity of the thermistor doesn't matter.
Any more ideas anyone? I suspect the main board may be faulty.
Thanks
Dieses Thema wurde geändert Vor 6 years von cneilson73
Veröffentlicht : 21/09/2020 5:40 am
Mitglied
RE: mintemp error, can't resolve
Are you sure the extruder is the problem - what temperature is reading on the display for the extuder and bed?
Veröffentlicht : 27/09/2020 1:37 pm
cneilson73
(@cneilson73)
Extruder is reading 0 degrees and dosen't move.
Veröffentlicht : 28/09/2020 4:39 am
Mitglied
Your thermistor on the hound had a broken wire.  You need to replace it.  I keep a couple on hand to replace broken ones.  Here is a link if you ar in the US from Amazon and Filatrruder.   You can also order from Prusa but the cost may be a little more.
Veröffentlicht : 28/09/2020 12:07 pm
cneilson73
(@cneilson73)
I brought 2 brand new complete hot ends (with thermistors) from Prusa. I've plugged both of them into the board with the same problem. I've confirmed the thermistors are OK by plugging them into the bed thermistor input. This is not the problem.
Veröffentlicht : 28/09/2020 9:00 pm
Mitglied
Contact support by chat.
Veröffentlicht : 28/09/2020 9:04 pm
