RE: Mintemp Error and Breaking Heatbed Thermistor
I wanted to write my experience with broken thermistor bed cable, but I just saw here that it's not so original! 😀
My break occurred after some printing of ASA, so I suspect that the higher bed temperature was the the straw that broke the camel's back.
I was thinking about replacing the cable with a much more flexible silicone insulated version, and I see that it's neither a so bad idea, nor so original.
I thought of other minor improvements here:
- The heatshrinking tube used to cover the joint between thermistor leads and cable is done with poliofelyn, a material cabable of withstaining 125 °C. As I'm on the job, I feel safer in the long run using something made of PDVF or silicone, that are capable to staying for undefinetly long periods at 175 °C and 200 °C respectively.
 - I don't get why insulated thermal paste is not used to improve the heat transfer between bed and thermistore, isn't better to apply it?
Of course being absolutely sure that it's a not conductive version.
Thanks for the advice on power bed cable, while on the job I'll replace also them!
ive got one printer that does this on some prints. Generally at the same height/spot on & above the bed. I cant repro the issue without running a print.
super super frustrating.
I wrote to Prusa and got very soon a new thermistor for free, as my printer is just few months old.
In the meanwhile I ordered on Aliexpress what I need to build a more reliable version next time it happens, as described above.
I'm replacing also power cables for the bed with flexible and heat resistant silicone insulated version, to be on a safer side.
What I really find frustating is having the MMU2s to work as expected 😉 , this at the end for me was surely annoying, but just a minor issue, easily solvable.
@joantabb
Hey - so ive been trying to find the time to manage the issue im having on this one printer of mine - and well... i finally got it on video!
Note that during PRINTING i get "mintemp bed" and am totally unable to repro this outside of a print but i was able to get this video...
the question is - what do i need to replace.
I think this cable and the nozzle themristor wires are the most common broken parts on the Prusa. I treat them as expendable.
@cwbullet
should last more than a month... i have originals running on other printers.
@benjamin-5
It depends on the stress you put on them. I broke my first one in abotu 2-3 months. I did not take the flex in wiring as it hit the back of my enclosure.
