MINTEMP error
Stránka 2 / 2
Roman
(@roman-8)
MINTEMP error
I understand safety precautions. However, I don't understand why the printer is set up so that it has to be restarted and I lost printing at 18 hours !!! Now that I'm afraid to ventilate at home while printing ...
Napsal : 10/01/2021 10:04 pm
RE: MINTEMP error
@roman-8
how did the printer get cold enough to give a Mintemp report if it was printing?
or did a thermistor fail?
Regards Joan
Napsal : 11/01/2021 1:43 am
pyronaught
(@pyronaught)
RE: MINTEMP error
I have four Prusas with about 1000 hours on them and I'm starting to see this error sproradically.  Since it is random I suspect an intermittent bad connection on the thermistor wires, just haven't got around to checking it yet.  I agree with roman-8 however that the way this error is being handled by the code is pretty misguided.  A Prusa can recover a print from a power outage but we lose the print when one of these min temp errors requires a reset?  The code needs to be changed so that the print can be recovered after the reset, just as with power loss.
Napsal : 13/01/2021 5:48 pm
Stránka 2 / 2
