MINTEMP error
I understand safety precautions. However, I don't understand why the printer is set up so that it has to be restarted and I lost printing at 18 hours !!! Now that I'm afraid to ventilate at home while printing ...
RE: MINTEMP error
@roman-8
how did the printer get cold enough to give a Mintemp report if it was printing?
or did a thermistor fail?
Regards Joan
RE: MINTEMP error
I have four Prusas with about 1000 hours on them and I'm starting to see this error sproradically. Since it is random I suspect an intermittent bad connection on the thermistor wires, just haven't got around to checking it yet. I agree with roman-8 however that the way this error is being handled by the code is pretty misguided. A Prusa can recover a print from a power outage but we lose the print when one of these min temp errors requires a reset? The code needs to be changed so that the print can be recovered after the reset, just as with power loss.
