Message at bottom of display "SHARPI"
I'm running a print. On line 4 of the base display it says "SHARPI->2.GCO" My gcode file is named "cup handle_0.2mm_PLA_MK3S_1h33m.gcode". I searched my gcode file for the string "SHARP" and found nothing.
Any hints about what this means?
RE: Message at bottom of display "SHARPI"
Can you post an image?
Have you contacted support on Chat? I would.
That's funny. Did it show the same file name in the selection screen? Did it print the right thing?
It's definitely the file name. Maybe some special characters in the filename. What's the firmware version?
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Firmware 3.9.0
I have not seen this in the selection screen. It did print the right thing. No special characters in the file name. It has not happened again.
Jim
