Max temp error, then blank screen, now printer stops while printing.
Page 4 / 6
Scottyos
(@scottyos)
RE: Max temp error, then blank screen, now printer stops while printing.
I'm getting a min temp error. should I put in the hot end thermister as well?
Posted : 08/01/2023 3:13 am
Hello
(@hello)
no in settings on the printer go to temprature then set nozzle to zero and heatbed to 80
Posted : 08/01/2023 3:16 am
Hello
(@hello)
what temp is bed at
Posted : 08/01/2023 3:18 am
Scottyos
(@scottyos)
So I had plugged in the extruder thermister and turned it on, set the bed to heat to 70 and then it just like overloaded and shut off. I pulled the extruder therm. and tried turning it on and it won't even power on at this point. This had happened before but after a little bit of time it had come on again.
Posted : 08/01/2023 3:19 am
Hello
(@hello)
thats why i said not to plug in hotend thermistor the psu has a safety fetaure in sometimes unplug from wall and then plug back into wall
Posted : 08/01/2023 3:22 am
Scottyos
(@scottyos)
I had just tried unplugging from the wall and plugging it back in, and it didnt want to turn on I'll give it a few minutes.
Is the goal to figure out what's causing the issue? It seems like the board may be screwed to me but I'm wondering if there's something that's causing issue to the board that we're trying to isolate?
Posted : 08/01/2023 3:23 am
Hello
(@hello)
did unpluging psu from wall work
Posted : 08/01/2023 3:24 am
Hello
(@hello)
thats why i am getting you to plug things in serpreitly so please dont plug in stuff when i tell you not to eg plugging in hotend thermistor so we can isolate error
Posted : 08/01/2023 3:27 am
Hello
(@hello)
check psu fuse quick just incase
Posted : 08/01/2023 3:28 am
Scottyos
(@scottyos)
Just plugged it back in and nothing is firing up. The board doesn't light up. nothing on the display.
Hello
(@hello)
check to see if power is comming out of psu
Posted : 08/01/2023 3:29 am
Hello
(@hello)
using multimeter
Scottyos
(@scottyos)
15 amp fuse is still good.
Posted : 08/01/2023 3:30 am
Scottyos
(@scottyos)
sorry let me check the psu fuse.
Hello
(@hello)
also check if power comming out of psu
Posted : 08/01/2023 3:36 am
Scottyos
(@scottyos)
PSU fuse is still good
Scottyos
(@scottyos)
How can I check power coming out of the psu with the multimeter? I've never done that before?
Posted : 08/01/2023 3:37 am
Hello
(@hello)
on the einsy power in wires
Posted : 08/01/2023 3:39 am
Hello
(@hello)
turn multimeter to the v symble then put negative on the negative wire and positve to positve
Posted : 08/01/2023 3:40 am
Hello
(@hello)
or take 3d printed cover of bottom of the psu and there should be a little board that the power panic conects to if the green light on that is on the psu is fine
Posted : 08/01/2023 3:42 am
Page 4 / 6
