Max temp error, then blank screen, now printer stops while printing.
Strona 2 / 6
Hello
(@hello)
RE: Max temp error, then blank screen, now printer stops while printing.
oh sorry i mean the ones that should be conected to the terminal block but when testing they need to be disconected
Opublikowany : 08/01/2023 2:29 am
Scottyos polubić
Scottyos
(@scottyos)
So the extruder heater is coming in at 15.2 ohms
Opublikowany : 08/01/2023 2:30 am
Scottyos
(@scottyos)
that's teh block with the two thicker red wires. I've also got the wiring guide from the assembly manual here as well. Again this was on the wire side of things.
Opublikowany : 08/01/2023 2:31 am
Hello
(@hello)
ok thats fine now conect lcd cables and psu cables
Opublikowany : 08/01/2023 2:32 am
Scottyos polubić
Hello
(@hello)
and all the motor cables
Scottyos polubić
Hello
(@hello)
and can you confirm about how old printer is what mk you have
Opublikowany : 08/01/2023 2:34 am
Scottyos polubić
Scottyos
(@scottyos)
so pinda, filament snsor, front print fan, left hotend fan, extruder heater and power panic disconnected?
just x y z e psu power and heatbed power and the lcd connected?
Opublikowany : 08/01/2023 2:35 am
Hello
(@hello)
oh and pinda sensor pluged in please sorry forgot about that
Scottyos polubić
Hello
(@hello)
now turn on
Opublikowany : 08/01/2023 2:36 am
Scottyos polubić
Hello
(@hello)
does it do normal booting process and got to normal home screen
Scottyos polubić
Scottyos
(@scottyos)
those are all plugged in now with the pinda.
Opublikowany : 08/01/2023 2:38 am
Hello
(@hello)
ok so now turn on and let me know if it does normal boot up process
Opublikowany : 08/01/2023 2:39 am
Scottyos polubić
Scottyos
(@scottyos)
not turning on, when i flipped on the power the screen flashed and made a small pop sound but nothing turned on. I had plugged in the power panic as well  I'll double check everything is in there good.
Opublikowany : 08/01/2023 2:41 am
Hello
(@hello)
that does not sound good make sure evrything is pluged in right by the way the reason why im getting you to do this is i belive the einsy is busted and trying to find the cause of it also check all fuses
Opublikowany : 08/01/2023 2:42 am
Scottyos polubić
Scottyos
(@scottyos)
 Fuses are good I had checked them before. If the einsy was busted would it still attempt to print and then just reset on it's own?
Opublikowany : 08/01/2023 2:43 am
Hello
(@hello)
yes because that would mean a trace on the board could be damaged. is it turning on
Opublikowany : 08/01/2023 2:44 am
Scottyos polubić
Hello
(@hello)
oh and i said fuses beacuse you said somthing poped when you just tryed to turn it on
Opublikowany : 08/01/2023 2:45 am
Scottyos polubić
Hello
(@hello)
but we need to check what caused the einsy to go bad
Opublikowany : 08/01/2023 2:46 am
Scottyos polubić
Scottyos
(@scottyos)
it was before I had a partial print come off tonight.  thpart on the left was from tongiht earlier. It had made it maybe to layer 4.
Opublikowany : 08/01/2023 2:47 am
Hello
(@hello)
einsy boards dont just go bad somthing causes it and when that thing does cause it it could happen again
Scottyos polubić
Strona 2 / 6
