Max temp error, then blank screen, now printer stops while printing.
Page 2 / 6
Hello
(@hello)
RE: Max temp error, then blank screen, now printer stops while printing.
oh sorry i mean the ones that should be conected to the terminal block but when testing they need to be disconected
Posted : 08/01/2023 2:29 am
Scottyos
(@scottyos)
So the extruder heater is coming in at 15.2 ohms
Posted : 08/01/2023 2:30 am
Scottyos
(@scottyos)
that's teh block with the two thicker red wires. I've also got the wiring guide from the assembly manual here as well. Again this was on the wire side of things.
Posted : 08/01/2023 2:31 am
Hello
(@hello)
ok thats fine now conect lcd cables and psu cables
Posted : 08/01/2023 2:32 am
Hello
(@hello)
and all the motor cables
Hello
(@hello)
and can you confirm about how old printer is what mk you have
Posted : 08/01/2023 2:34 am
Scottyos
(@scottyos)
so pinda, filament snsor, front print fan, left hotend fan, extruder heater and power panic disconnected?
just x y z e psu power and heatbed power and the lcd connected?
Posted : 08/01/2023 2:35 am
Hello
(@hello)
oh and pinda sensor pluged in please sorry forgot about that
Hello
(@hello)
now turn on
Posted : 08/01/2023 2:36 am
Hello
(@hello)
does it do normal booting process and got to normal home screen
Scottyos
(@scottyos)
those are all plugged in now with the pinda.
Posted : 08/01/2023 2:38 am
Hello
(@hello)
ok so now turn on and let me know if it does normal boot up process
Posted : 08/01/2023 2:39 am
Scottyos
(@scottyos)
not turning on, when i flipped on the power the screen flashed and made a small pop sound but nothing turned on. I had plugged in the power panic as well  I'll double check everything is in there good.
Posted : 08/01/2023 2:41 am
Hello
(@hello)
that does not sound good make sure evrything is pluged in right by the way the reason why im getting you to do this is i belive the einsy is busted and trying to find the cause of it also check all fuses
Posted : 08/01/2023 2:42 am
Scottyos
(@scottyos)
 Fuses are good I had checked them before. If the einsy was busted would it still attempt to print and then just reset on it's own?
Posted : 08/01/2023 2:43 am
Hello
(@hello)
yes because that would mean a trace on the board could be damaged. is it turning on
Posted : 08/01/2023 2:44 am
Hello
(@hello)
oh and i said fuses beacuse you said somthing poped when you just tryed to turn it on
Posted : 08/01/2023 2:45 am
Hello
(@hello)
but we need to check what caused the einsy to go bad
Posted : 08/01/2023 2:46 am
Scottyos
(@scottyos)
it was before I had a partial print come off tonight.  thpart on the left was from tongiht earlier. It had made it maybe to layer 4.
Posted : 08/01/2023 2:47 am
Hello
(@hello)
einsy boards dont just go bad somthing causes it and when that thing does cause it it could happen again
Page 2 / 6
