					                		Manually adjust heat bed thermister calibration temp??? - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/manually-adjust-heat-bed-thermister-calibration-temp/</link>
                <lastBuildDate>Thu, 16 Apr 2026 01:48:23 +0000</lastBuildDate>
                        <title>RE: Manually adjust heat bed thermister calibration temp???</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/manually-adjust-heat-bed-thermister-calibration-temp/#post-768553</link>
                        <pubDate>Sat, 01 Nov 2025 02:28:29 +0000</pubDate>
                        <description><![CDATA[HiI have calibrated the heat bed thermister.  I have determined it measures 8 deg low at 80 deg C.  If i want the bed to be 80 deg C, I have to set the bed temperature to 88 deg C.    Knowin...]]></description>
                        <content:encoded><![CDATA[<p>Hi</p><p>I have calibrated the heat bed thermister.  I have determined it measures 8 deg low at 80 deg C.  If i want the bed to be 80 deg C, I have to set the bed temperature to 88 deg C.    Knowing the calibration results and thermister error, does not help me tell the Prusa the sensor is wrong.  </p><p>Given the importance of temperature for both the heat bed and the extruder, I believe the firmware should allow a user to calibrate the thermisters.  </p><p>The work around is to change the settings in the profile, but this is a work around and not a solution.  There should be a process to calibrate the temperature sensors.  </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Dazz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/manually-adjust-heat-bed-thermister-calibration-temp/#post-768553</guid>
                        <title>Manually adjust heat bed thermister calibration temp???</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/manually-adjust-heat-bed-thermister-calibration-temp/#post-765843</link>
                        <pubDate>Tue, 30 Sep 2025 04:13:30 +0000</pubDate>
                        <description><![CDATA[HiI have replaced my heat bed thermister but now the bed temperature is 20 degrees C less than indicated on the LCD panel.   I measured the room temp resistance at 127k ohm. It is supposed t...]]></description>
                        <content:encoded><![CDATA[<p>Hi</p><p>I have replaced my heat bed thermister but now the bed temperature is 20 degrees C less than indicated on the LCD panel.   I measured the room temp resistance at 127k ohm. It is supposed to be 100k ohm. That is about the same % error I am seeing in the temperature.     </p><p>Is there a way of manually adjusting the thermister room temp resistance in the software?  </p><p>Doing a calibration from the LCD does not fix the problem that the thermister is indicating the temperature about 20% higher than it really is, so the bed is cold.</p><p>I figure there is somewhere in the software that sets the room temperature thermister resistance at 100k.  I want to change that to about 127k.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/manually-adjust-heat-bed-thermister-calibration-temp/#post-765843</guid>
