Manually adjust heat bed thermister calibration temp???
Hi
I have replaced my heat bed thermister but now the bed temperature is 20 degrees C less than indicated on the LCD panel. I measured the room temp resistance at 127k ohm. It is supposed to be 100k ohm. That is about the same % error I am seeing in the temperature.
Is there a way of manually adjusting the thermister room temp resistance in the software?
Doing a calibration from the LCD does not fix the problem that the thermister is indicating the temperature about 20% higher than it really is, so the bed is cold.
I figure there is somewhere in the software that sets the room temperature thermister resistance at 100k. I want to change that to about 127k.
Napsal : 30/09/2025 4:13 am
