Live Adjust: Which way is down?
I am getting myself a little confused,, when doing live adjust is the bigger minus number, lower/closer to the bed?
So for example, -0.500 is closer to the bed than -0.300?
Opublikowany : 29/10/2018 7:57 pm
Re: Live Adjust: Which way is down?
Yes, that is correct. More negative is closer to the bed.
Opublikowany : 29/10/2018 8:07 pm
Number Line:
-9 -8 -7 -6 -5 -4 -3 -2 -1 0 1 2 3 4 5 6 7 8 9
So left(er) is low(er)
Hope that helps,
Neal
Opublikowany : 29/10/2018 8:09 pm
the first one i guess
Opublikowany : 29/11/2018 12:59 pm
On the Mk3, more negative equals lower (closer to the bed). I've been told that the Mk2 is reversed, so do keep that in mind if you're replying to a Mk2 thread.
Opublikowany : 29/11/2018 6:00 pm
