Issue with G-Code for tool change ("next_extruder")
Hello,
This command should work when I add it to the "tool change" section, but I cannot figure out why it does not (Prusa Slicer complaints about an error that has occurred while slicing):
M104 S[temperature[next_extruder]]
"previous_extruder" does work either, so I am at a loss. I replaced "[next_extruder]" with a number and it seem to be okay.
According to this documentation this should do the job.
Any idea?
3D Druck für Einsteiger leicht gemacht: www.3d-druck-lernen.de
RE: Issue with G-Code for tool change ("next_extruder")
I think we can close this thread. This has not been implemented for Prusa devices and Prusa Slicer, respectively. Too bad...
Is it this ??
M104 S[temperature_[next_extruder]]
note: this only works in tool change gcode
temperature
M109 S[temperature_0] M109 S[temperature_[previous_extruder]]
My apologies, I missed the underscore. But the result is the same I am afraid. I add a
to the "tool change" section and Prusa Slicer complains. If I add this, however:
M104 S[temperature_0]
Prusa Slicer has no issues with it...
M104 S[temperature_[next_extruder]]to the "tool change" section and Prusa Slicer complains. If I add this, however:
M104 S[temperature_0]Prusa Slicer has no issues with it...
I ran into this issue and seem to have stumbled upon the solution after several hours of throwing everything at the wall to see what sticks. The g-code parser doesn't seem to like nested brackets, replace the outer brackets with braces:
M104 S{temperature[next_extruder]}
I suspect this is part of the inconsistant logic around multiple extruders, sometimes you need to reference as an array index eg 104 S{first_layer_temperature[0]*0.9}, sometimes it assumes index 0 and some times curly not square brackets.
BTW not 100% sure about my example, there may be some syntax that works without the array usage but have tried a bunch of things this was suggested and is works and it makes sense, as it depend on which material forms the first layer.
Isn't there some sense of static versus dynamic syntax here? That when an evaluation needs to happen curly braces are needed?
[offset+1] doesn't work but {offset+1} does?
@tim-m30 "Isn't there some sense of static versus dynamic syntax here?" Damned if I know but I strongly suspect that you do. Could you give an example that demonstrates the difference between the two?
{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; Move print head up
This statement supports both my assertion, which is an educated guess, and what michael said.
Said another way, if you need the interpreter to evaluate something from multiple values, curly braces are required.
Here's a slightly different example of the same thing:
total_layer_count
M117 printing layer {layer_num+1}/[total_layer_count]
.. [total_layer_count] doesn't need any evaluation: it simply points to a number in memory. {layer_num+1} needs to be evaluated - the sum of a number in memory and a number in the gcode. Think of it as {[layer_num]+1} ...
https://github.com/prusa3d/PrusaSlicer/wiki/Slic3r-placeholders-(a-copy-of-the-mauk.cc-page)
But then Prusa comes along has has a better idea... lol.
https://github.com/prusa3d/PrusaSlicer/wiki/Slic3r-Prusa-Edition-Macro-Language
I think a hidden surprise is this text:
Multidimensional vectors can currently be only accessed as a simple vector variables resulting in a string value (e.g. if the
extruder_offsetplaceholder holds a value of 0x0,nx0 it can only be accessed asextruder_variable[1]resulting in [n,0] string value -- can be posted in g-code but can not be used in arithmetic operations).
There are things that evaluate to strings and things that evaluate to numerics.
ps: in those links it explains why the OP's expression fails.
should be written
What isn't well explained and must be inferred by example is that underscore as a vector indicator. Normal languages use var[x] - yet Prusa or other gcode gods chose var_x - and the added convolution of requiring brackets for var_[x] ...
ps: then again - can't test any of this without an MMU profile ...
But if
doesn't work and
does work, try
M104 S{temperature_[next_extruder]}
