Issue with flashing firmware
corb printer
(@corb-printer)
I have recently factory reset my i3 MK3, and I am now trying to flash the firmware back onto the printer. The issue is when I try to flash the printer wont show up as a serial port. I have the printer turned on and a USB type B connected to it. One question I have is: do I need to use the cable that came with the printer, or can I use any USB type B?
Publié : 26/09/2023 4:31 am
RE: Issue with flashing firmware
any standard USB A to B cable, should work
on the lcd menu, can you check that the internal Raspberry pi connection is turned off? the USB functionality is shared between the usb port and the internal raspi port!
are you using prusa slicer to flash the firmware?
Publié : 26/09/2023 8:57 am
corb printer
(@corb-printer)
Yes I am using the prusa slicer.
Publié : 26/09/2023 3:17 pm
corb printer
(@corb-printer)
I turned off the RPi port and that did not fix the issue. the printer is still not showing up on the serial port list.
Publié : 26/09/2023 3:27 pm
Oh dear. have you loaded the Prusa Driver set?
https://help.prusa3d.com/downloads
Publié : 26/09/2023 6:22 pm
corb printer
(@corb-printer)
Yes I downloaded both the firmware and the drivers and apps.
Publié : 26/09/2023 10:20 pm
Hello
(@hello)
Posted by: @corb-printer
Download printoface and see if it sees the printer on the com port
Publié : 27/09/2023 1:29 am
corb printer
(@corb-printer)
Would you be able to send a link for that? Thank you for your help so far.
Publié : 27/09/2023 2:36 am
Hello
(@hello)
Sure thing https://www.pronterface.com/
Publié : 27/09/2023 7:05 am
Hello
(@hello)
Also you say your trying yo flash firmware back onto printer are you saying there is currently no firmware on the printer
Publié : 27/09/2023 8:05 am
corb printer
(@corb-printer)
Yes, I had to factory reset it.
Publié : 27/09/2023 3:52 pm
Hello
(@hello)
Yeah but it will still have firmware on it are you saying you want to up date the firmware to a newer version
Publié : 27/09/2023 10:35 pm
corb printer
(@corb-printer)
Yes, the main goal is to update the firmware to hopefully solve my problems with the first layer calibration.
Publié : 30/09/2023 3:03 am
Hello
(@hello)
DI'd you try pronterface
Publié : 30/09/2023 6:34 am
