Issue with firmware versions that use Thermal Model calibration.
on my Mk3S+, I had a blob of death, and it destroyed my factory E3dV6 hotend, so rather than just replace it, I decided to upgrade to a E3dRevo6. I bought it when the firmware support was not yet implemented for the revo6 in the newer firmware versions which have the new Thermal Model Calibrations, so I rolled back to 3.11.0-4955, which worked fine for me.
Currently I am trying to get the Revo specific firmware version 3.13.3-7094 to work, as i am upgrading to MMU3. and it requires version 3.13.0 or higher.
The issue is, no matter what i try i cannot get the Thermal Model Calibration to pass. When activating the hotend, it will almost immediately give a thermal anomaly error (usually 1 to 2 seconds after starting heating). This also occurs if i try a PID calibration, however during PID calibration there is no error, however the hotend set temp drops to zero and the menu on the LCD hangs.
Here is what the printer send to the serial console when attempting a TM Calibration;
TM: calibration start
LCD status changed
TM: initial C est.
echo:busy: processing
TM: error |1.267498|>1.200000
TM: error |1.463057|>1.200000
TM: error |1.642880|>1.200000
LCD status changed
TM: calibr. failed!
echo:Thermal Model settings:
echo: M310 I0 R17.31
echo: M310 I1 R15.86
echo: M310 I2 R14.41
echo: M310 I3 R11.50
echo: M310 I4 R10.84
echo: M310 I5 R10.18
echo: M310 I6 R9.52
echo: M310 I7 R8.85
echo: M310 I8 R8.58
echo: M310 I9 R8.30
echo: M310 I10 R8.02
echo: M310 I11 R7.74
echo: M310 I12 R7.59
echo: M310 I13 R7.43
echo: M310 I14 R7.28
echo: M310 I15 R7.12
echo: M310 P38.00 U0.0000 V1.00 C14.79 D0.0650 L2160 S1 B0 E1.74 W1.20 T-7.00
TM: error |1.748293|>1.200000
TM: error triggered!
