Incorrect negative value in generic-slab Z-Height
Andrew
(@andrew-12)
I have recently found a bug in the allocation of the z-height when inserting a slab into a part for use in multi-colour printing using the Mk3S-MMU2S.
When creating a slab, instead of presenting the height as a positive value above the surface it requires a negative value to set position. This also prints correctly when using a negative height.
Requires correction in software.
Negative z-height
Regards,
Andrew.
This topic was modified 7 years ago by Andrew
Posted : 10/06/2019 12:30 am
RE: Incorrect negative value in generic-slab Z-Height
You'll need to post your defect to the github issues list otherwise developers will not see it.
Posted : 10/06/2019 2:10 am
