IN SEARCH OF: Meaningful Linear Advance Calibration
Stránka 2 / 2
Re: IN SEARCH OF: Meaningful Linear Advance Calibration
I may have figure out part of what's going on. Hollow prints always print external perimeters at slow speed, regardless of speed or linear advance settings:
One primary reason hollow prints print slow is due to this setting:
Napsal : 02/04/2019 7:41 pm
Ah, good point! I am well aware of that setting, just didn't consider it. Checking this out, it's a bit interesting. I set min print times to 500:
But print speeds remained low. I'd expected the min print speed to only kick in if times were exceeded:
Upped the min print speed:
And now it prints fast (still respecting max speeds and max volumetric speeds):
I'm learning more about SLic3rPE at the moment than LA.
Re-generating my test tower, but have to deal with the dentist for a bit...
Napsal : 02/04/2019 8:29 pm
Active English: SLOW DOWN IF TIME IS BELOW [xxxx]
I set mine to [ 1] and it worked well and kept printing at my higher speeds.
Napsal : 03/04/2019 12:40 am
I knew that. Doh. OK I blame the dentist!
I am getting some observable results now. Will update once my brain isn't numb.
Edit: Success! I'm still tweaking sizing and wall thickness, trying to keep the print below 30 minutes, but this is encouraging:
You can see the bulging corners gradually decreasing from left to right as LA is applied in increments of 5.
I'm going to try to expand this idea to jerk & acceleration tuning. I want to try it for speed (M220) and extrusion rate (M221) tuning as well. I want to find optimal values for a variety of materials and nozzle sizes.
Thanks for the feedback guys! It's been very helpful. @tim.m30, I'm going to stick with novocaine poisoning as my excuse for the brain cramps.
Napsal : 03/04/2019 3:58 am
Bunny Science
(@bunny-science)
Perfect! You cracked that problem.
Napsal : 03/04/2019 8:51 am
Just a final update. I've found a good combination of test piece parameters to show the impact of Linear Advance quite clearly.
You can see the "dogbone" effect in corners with LA set to 0 at left, transitioning to rounding off as LA moves higher to the right:
The impact on the z-seam is also quite apparent, moving from puckered with LA set to 0 at left, transitioning to split as LA moves higher to the right:
I've attached configs and samples for a smaller PLA test tower for LA values 15 to 45 if anybody's interested.
Napsal : 04/04/2019 8:56 pm
Bunny Science
(@bunny-science)
I basically never print PLA. Here is how I attempted to change it for PETG.
Opene your amf file
Importing the ini file
Change the filament to PETG
G-Code looks right. Is infill supposed to be 15% gyroid?
Napsal : 04/04/2019 9:32 pm
[...] Change the filament to PETG
Yes and be sure to set that cooling minimum layer time to "1" or some suitably low value. I now make a point of checking speed in preview before saving the gcode out. Wasted a lot of time using lower speeds. I find that external perimeter speeds below 60mm/s don't really show much effect.
Yes, but there really shouldn't be any infill. I've created a smaller PETG tower, but no test prints yet. See attached.
I've generated towers testing the impact of acceleration, jerk & speed on otherwise-identical prints. Nothing earth-shattering, but it is interesting see each parameter's impact on print quality in isolation.
Napsal : 04/04/2019 10:23 pm
Spacemarine
(@spacemarine)
Thanks for the hint!
I requested a feature some months ago, which would help to resolve these situations: Show limiting factor for printing speed
https://github.com/prusa3d/Slic3r/issues/1490
Unfortunately, this request didn't get much attention.
Napsal : 05/04/2019 11:30 pm
A bit off topic, but a drill down to find the limits would be a nice secondary feature; but what I want is something that explains - in plain English - a simple gcode command like G1 E0.80000 F2100.00000 : G1 F982 : G1 X121.959 Y112.292 F10800.000 : G1 F8640 ...
I want a command to set acceleration over a distance, not some random percentage of some other trait like base speed or max speed minus base speed after applying some other slow down multiplied by a tic-tok timer of third relevance in the command queue.
venting complete
Napsal : 05/04/2019 11:54 pm
Spacemarine
(@spacemarine)
Why not request it on github and start a discussion about it in a separate topic here in the forum?
Napsal : 06/04/2019 12:03 am
RE: IN SEARCH OF: Meaningful Linear Advance Calibration
Looks like the project file upload was lost. I've attached it to this post.
Attachment removed
Napsal : 25/11/2019 3:43 pm
In case you're having trouble finding the LA Test Tower, I'm attaching it again here.
Attachment removed
Napsal : 12/12/2019 4:08 pm
vintagepc
(@vintagepc)
Nice work. Will this be updated when 1.5 is officially supported? Or do you already have an LA1.5 version?
Napsal : 12/12/2019 4:24 pm
Posted by: @vintagepc
I'm on stock firmware so whenever that gets updated, I'll try to revisit everything. The gcode is fairly straightforward to edit if someone wants to give it a spin with 1.5 in the meantime. Let me know what values you want to test and I can easily generate a new test model with the proper labels. Happy to share the OpenSCAD source as well.
Napsal : 12/12/2019 4:42 pm
1 lidem se líbí
theamzngq
(@theamzngq)
Now that 3.9.0 with LA 1.5 is out, have you reworked your test project at all?
Napsal : 10/09/2020 7:57 pm
Posted by: @david-w33
I'm doing updates on my notes pages but haven't re-printed the tower with new values yet. It's in my pipeline.
I have found that the automatic translation between LA1.0 and LA1.5 isn't ideal, so I'm going to do my own calibration for each filament over again.
Napsal : 10/09/2020 8:23 pm
vintagepc
(@vintagepc)
You may want to hold off a bit. 3.9.1 will change the values again now that they've fixed some bugs in the initial implementation.
It should also fix the conversion to better values.
Napsal : 10/09/2020 10:05 pm
Good to know. I've got 3.9.1Rc1 running now, but I'll shuffle other updates ahead of the update. Thanks.
Napsal : 11/09/2020 1:33 am
Stránka 2 / 2
