How to change pattern of first layer support in Slic3r?
connorbadenko
(@connorbadenko)
Hi there,
I'm having huge problems with my first layer of support not sticking and peeling up as seen in the image below. I've tried many different settings and even when slowing down the first layer to 5 or 10mm/s, i still get the peeling.
https://imgur.com/255E2bk
Is there any way to change the first support layer pattern in Slic3r? Even if i change the support pattern to something like Rectilinear grid, the first layer always stays the same. Alternatively, is there any setting i'm missing which can slow down just the first layer of support (not the entire first layer)?
Thank you!
This topic was modified před 7 years 2 times by connorbadenko
Napsal : 27/04/2019 1:10 am
RE: How to change pattern of first layer support in Slic3r?
Posted by: connorbadenko
You are suffering from bed adhesion problems. The part pops off the PEI surface and gets dragged around. Here's some copypasta...
Adhesion problems are usually caused by 2 main problems:
  • A dirty PEI print surface. Even if you don't think this is the cause, it's always a good idea to make sure your PEI surface is clean before trying any other fixes. Take it to the kitchen sink and give it a good dunk with Dawn (original formula, no vinegar or hand softener variants) dishwashing soap or your local equivalent (e.g. Fairy in UK). Use a clean paper towel to clean it off, and another to dry it. Avoid using any sponge or cloth that has been in contact with grease. Above all else, avoid touching the PEI print surface. Once it's good and clean, you should be able to use 91%+ isopropyl alcohol between prints, 100% acetone when that fails, and another dunk when acetone fails. Worst-case, use a 3M 7445 ScotchBrite pad or equivalent to give it a very light buff, but only infrequently.
  • If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the on-board routine.
And above all else, avoid touching the PEI print surface.
Try those 2 steps. If you're uncertain of the Live-Z results, post pics here of the 75x75 print bottom and you'll get quick help. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When it's right, you should be able to gently rub it without it coming loose. Then start lowering (more negative) the level until there are no gaps between layers.
If you want more detail, I've dumped everything I know about adhesion and bed cleaning here and Live-Z calibration here (draft).
Napsal : 27/04/2019 1:36 pm
Sharif
(@sharif)
I think @connorbadenko is referring to supports not sticking, not the object.  My objects stick just fine, but the supports don't.  I'm looking for a fix too.  But for now I just add a thin pad object under the supports and it works just fine.
See pad in picture -
This post was modified před 6 years by Sharif
Napsal : 03/08/2019 4:32 pm
Posted by: sharif
It's the same issue. The bed has to be properly clean and Live-Z properly calibrated to get good supports. Believe me, I struggled with this looking for the magic answer before it finally sunk in that it's all about 1st layer adhesion. Once you get your surface properly cleaned and Live-Z adjusted, support print quite well with no voodoo required.
You guys didn't mention whether you're printing on a smooth or textured surface. The Prusa instructions for the textured sheet have changed (only recommend isopropyl alcohol now), and PLA can be a PITA on the textured sheet. Let us know if which you're using.
Napsal : 03/08/2019 6:21 pm
This is a dirty bed - and had just been washed in alcohol:
A scrub at the sink with dish soap and lots of hot water fixed the adhesion problem.
This post was modified před 6 years 2 times by --
Napsal : 04/08/2019 4:36 am
ps: There is no way to alter the 50% filled support base pattern. You can change the angle, but not the pattern.
Napsal : 04/08/2019 4:55 am
1 lidem se líbí
Sharif
(@sharif)
Thanks
Napsal : 04/08/2019 1:47 pm
Sharif
(@sharif)
I was using a textured surface.  My bed is clean and everything sticks well to it.  It is just this one part for some reason at about 20MM height, it pulls the support off.  I tried it twice on this part and it pulled it at same spot.    I have moved on but maybe I'll try adjusting the 1st layer angle as a test for this part.  My printer has been going non-stop since I got it!  So cool...
Napsal : 04/08/2019 1:56 pm
Sharif
(@sharif)
Finished Part....
Napsal : 04/08/2019 2:05 pm
Posted by: sharif
Finished Part....
Did you print that as one piece or assemble the 2 halves you showed in the slicer preview?
Napsal : 04/08/2019 2:40 pm
Sharif
(@sharif)
The original picture was when I printed 1/2 of wheel hub.  It turned out so well, I printed the entire part as one as shown in the final picture.  Once the complete assembly is finished, I'll need to make a few more.  I'll eventually print another 1/2 and glue them together for a 2nd wheel assembly.
Napsal : 04/08/2019 3:59 pm
Posted by: sharif
[...] I'll eventually print another 1/2 and glue them together for a 2nd wheel assembly.
If you can chamfer that transition, the halves can very likely be printed inverted with no support. If you can link to the STL we might be able to offer more advice.
Napsal : 04/08/2019 5:05 pm
