					                		How to Adjust Crash Sensitivity - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/</link>
                <lastBuildDate>Tue, 09 Jun 2026 20:57:34 +0000</lastBuildDate>
                        <title>RE: How to Adjust Crash Sensitivity</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-500107</link>
                        <pubDate>Sat, 11 Sep 2021 11:08:30 +0000</pubDate>
                        <description><![CDATA[@karl-herbertI use the FW 3.10.1 and have a MK3S+]]></description>
                        <content:encoded><![CDATA[<p>@karl-herbert</p><p>I use the FW 3.10.1 and have a MK3S+</p><p> </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>who1sjoe</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-500107</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-500104</link>
                        <pubDate>Sat, 11 Sep 2021 11:03:17 +0000</pubDate>
                        <description><![CDATA[@who1sjoeWhich FW version and which printer (MK3 or MK3S)?wbr,Karl]]></description>
                        <content:encoded><![CDATA[<p>@who1sjoe</p><p>Which FW version and which printer (MK3 or MK3S)?</p><p>wbr,</p><p>Karl</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>karl-herbert</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-500104</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-499843</link>
                        <pubDate>Fri, 10 Sep 2021 17:26:31 +0000</pubDate>
                        <description><![CDATA[@karl-herbertI have a similar problem. Is it possible that you can also help me with the definition of TMC2130_SERVICE_CODES_M910_M918?Thanks in advance]]></description>
                        <content:encoded><![CDATA[<p>@karl-herbert</p><p>I have a similar problem. Is it possible that you can also help me with the definition of TMC2130_SERVICE_CODES_M910_M918?</p><p>Thanks in advance</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-499843</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435703</link>
                        <pubDate>Thu, 13 May 2021 10:30:04 +0000</pubDate>
                        <description><![CDATA[@gmbartonglad it helped temporarily. I would still check the mechanics of the axles for irregularities.]]></description>
                        <content:encoded><![CDATA[<p>@gmbarton</p><p>glad it helped temporarily. I would still check the mechanics of the axles for irregularities.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435703</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435583</link>
                        <pubDate>Thu, 13 May 2021 05:47:40 +0000</pubDate>
                        <description><![CDATA[Success!With the modified firmware, I set the Y sensitivity to 7 and successfully ran an ABS print that was 40mm tall. In 3 previous attempts, it would keep &quot;crash detecting&quot; around 1mm heig...]]></description>
                        <content:encoded><![CDATA[<p>Success!</p><p>With the modified firmware, I set the Y sensitivity to 7 and successfully ran an ABS print that was 40mm tall. In 3 previous attempts, it would keep "crash detecting" around 1mm height and I was unable to get it to progress any further.</p><p>Thanks @karl-herbert!</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>gmbarton</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435583</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435262</link>
                        <pubDate>Wed, 12 May 2021 19:09:56 +0000</pubDate>
                        <description><![CDATA[@gmbartonsent you a pm!]]></description>
                        <content:encoded><![CDATA[<p>@gmbarton</p><p>sent you a pm!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435262</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435133</link>
                        <pubDate>Wed, 12 May 2021 17:06:46 +0000</pubDate>
                        <description><![CDATA[@karl-herbertI used Visual Studio Code on Windows 10. The firmware I&#039;m trying to modify is MK3S 3.10.0.Thanks.]]></description>
                        <content:encoded><![CDATA[<p>@karl-herbert</p><p>I used Visual Studio Code on Windows 10. The firmware I'm trying to modify is MK3S 3.10.0.</p><p>Thanks.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435133</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435118</link>
                        <pubDate>Wed, 12 May 2021 16:55:21 +0000</pubDate>
                        <description><![CDATA[@gmbartonWhich editor did you use to make the changes? Originally this should look like this (3.8.1):/*!### M915 - Set TMC2130 silent mode &lt;a href=&quot;https://reprap.org/wiki/G-code#M915:_Se...]]></description>
                        <content:encoded><![CDATA[<p>@gmbarton</p><p>Which editor did you use to make the changes? Originally this should look like this (3.8.1):</p><p>/*!<br />### M915 - Set TMC2130 silent mode &lt;a href="https://reprap.org/wiki/G-code#M915:_Set_TMC2130_silent_mode"&gt;M915: Set TMC2130 silent mode&lt;/a&gt;<br />Not active in default, only if `TMC2130_SERVICE_CODES_M910_M918` is defined in source code.<br />*/<br />case 915:<br />{<br /><span style="color: #ff6600">   tmc2130_mode = TMC2130_MODE_SILENT;</span><br /><span style="color: #ff6600">   update_mode_profile();</span><br /><span style="color: #ff6600">   tmc2130_init();</span><br />}<br />break;</p><p>/*!</p><p>Which firmware version exactly do you need (MK3 3.10.0 or MK3S 3.10.0....or an older version)?<br />I could provide you with the changes.</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435118</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435058</link>
                        <pubDate>Wed, 12 May 2021 15:30:09 +0000</pubDate>
                        <description><![CDATA[@karl-herbertThanks for the video! This clearly explains many things I was missing in recompiling the code. Now I get this error in Arduino when I check firmware.ino in ArduinoBecause I have...]]></description>
                        <content:encoded><![CDATA[<p>@karl-herbert</p><p>Thanks for the video! This clearly explains many things I was missing in recompiling the code. Now I get this error in Arduino when I check firmware.ino in Arduino</p><p>Because I have activated TMC2130_SERVICE_CODES_M910_M918, what do I need to include as arguments for tmc2130_init() ?</p>
<div id="wpfa-87466" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.prusa3d.com/wp-content/uploads/wpforo/default_attachments/1620833409-Arduino-error.png" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;Arduino-error.PNG</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-435058</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-434776</link>
                        <pubDate>Wed, 12 May 2021 02:26:28 +0000</pubDate>
                        <description><![CDATA[Posted by: @gmbarton I&#039;m getting a lot of Y crashes for no apparent reason. The belt status is good (264).I&#039;ve heard that the crash sensitivity can be reduced with the lineM916 Y5 ; reduce y...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="153103" data-postid="434602" data-mention="gmbarton"><div class="wpforo-post-quote-author"><strong> Posted by: @gmbarton </strong></div><p>I'm getting a lot of Y crashes for no apparent reason. The belt status is good (264).</p><p>I've heard that the crash sensitivity can be reduced with the line</p><p>M916 Y5 ; reduce y crash sensitivity, default 3 max 63, higher numbers less sensitive</p><p>But then I read that TMC2130_SERVICE_CODES_M910_M918 must be enabled for the M916 code to work. How do I do that? Does that change need to be made to the firmware? If so, how?</p><p>Any help will be appreciated.</p></blockquote><p>I had a lot of crashes on one printer.  I turn off the detection.  It went away after I reinstalled the firmware.  It now works with the crash detection turned on.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/how-to-adjust-crash-sensitivity/#post-434776</guid>
