How can I completely disable Thermal Model Protection and everything to do with it?
Inglemation
(@inglemation)
I just updated to the latest firmware. I have an MK3S+ with the E3D Revo hotend. I have already read all of Prusa's official articles that I could find that pertain to this topic, and I've found that the entire Thermal Model Protection system and "Calibrate Thermal Model" functions are not compatible with the Revo. I found a Prusa article called Thermal Model Calibration. In the last paragraph of this article, it tells you how to supposedly disable this function: "The thermal model protection can be disabled by connecting the printer to your computer (Octoprint, PuTTY...), and sending M310 S0. An additional M500 will save the setting and the Thermal model protection will remain disabled after the next restart."
I followed these instructions, and now my printer no longer throws alarms about THERMAL ANOMALY all the time, which is nice, but here's the problem. Every time I turn on my printer, there's a prompt that says something to the effect of "Thermal model not yet configured", and it makes me address the prompt by pressing the dial. I have tried to configure a thermal model just so that it will shut up and quit telling me what I already know, but because I have a Revo, it never lets me get through the configuration process. There is always a THERMAL ANOMALY error that interrupts the process.
My printer is out in the garage, while my computer is set up in my office in the basement. I run OctoPrint from my computer, and there is always some degree of running back and forth involved. But now this annoying problem makes it so that I have to turn on my printer, run downstairs to my computer and connect OctoPrint to the printer (which resets the printer and makes the prompt appear), then run back upstairs and acknowledge this stupid prompt, then go back downstairs and start the print.
Is there any way I can just completely obliterate everything and anything to do with this stupid thermal model protection? It is completely and utterly unnecessary for me to have, and it's extremely frustrating that it's not more straightforward to disable, especially because tons of people are using the Revo and OctoPrint. I am blown away that there isn't just a simple Enable/Disable prompt inside the printer's LCD controller. Any help would be very much appreciated.
Opublikowany : 15/01/2023 8:36 pm
2 ludzie polubili
RE: How can I completely disable Thermal Model Protection and everything to do with it?
You might want to read https://github.com/prusa3d/Prusa-Firmware/issues/3636#issuecomment-1380243362
Opublikowany : 15/01/2023 9:12 pm
Inglemation
(@inglemation)
Thank you very much for the reply. I'm reading it over now and trying to decipher it, as I'm not super adept at programming. If I'm understanding this correctly, it seems that I just need to send the "D3 Ax0ca6 X1f" command when I'm sure that the rest of the calibration wizard is complete, aside from the Thermal Model Calibration, of course. And I need to do it from OctoPrint, as this command will not play nicely with PronterFace.
Thanks again for the response. Hoping this workaround succeeds. Still a little bewildered as to how this wasn't thought through a little bit more before the release. Revo upgrades are so ubiquitous now that it seems like it should be a pretty big red flag for the devs if::
1) Thermal Model Protection doesn't work for Revo-modded printers
2) Disabling this part of the firmware update doesn't address an LCD prompt after every single restart and new serial connection
3) The prompt request can't be fulfilled, again due to the presence of a Revo
4) There is no proper way to disable the prompt without terminal commands from OctoPrint, which also affect other parts of the setup wizard
Again, I'm just a little blown away that this was missed. I'm sure it's a huge issue and a point of frustration for a lot of Prusa users right now, and I'm sure my post won't be the last on this topic. I feel bad for anyone out there who has a Revo and doesn't have OctoPrint, as it seems that this issue is unsolvable without OctoPrint. Unless, of course, you just want to revert back to the previous firmware. Hopefully it gets fixed soon.
Opublikowany : 15/01/2023 9:36 pm
ulfert.g
(@ulfert-g)
Same here, MK3S+ with Revo, I've ended up downgrading to 3.11 for the time being.
Since the main feature of 3.12 seems to be the thermal model protection and it's conflicting with Revo, I figured a downgrade is the easiest way to go for now.
Posted by: @inglemation
Opublikowany : 20/01/2023 8:13 pm
Escrich
(@escrich)
The best way:
Thermal image disabling on Prusa
M310 S0
M500
After that:
PID Nozzle tunning
M303 C5 S240
PID Bed tunning
M303 E-1 C5 S60
Don't forget to repeat the whole steps at every firmware update, I have minimum changes, at least I can consider them as no changes, and I have problems with them, the best is to disable the thermal image, at least from my point of view, my original Prusa MK3S+, mounted in factory, was running pretty well, since 2019, before of the last two firmware updates were applied
https://github.com/Escrich . https://t.me/escrich . https://www.tiktok.com/@josemescrich
Opublikowany : 17/04/2023 8:06 pm
Jared Spink
(@jared-spink)
Thank you for this thread!
I just installed the Revo after my stock heater block shorted (figured it was time to upgrade). After installing the revo on 3.12.1, I kept getting the "thermal anomaly" message when applying power to the heater block (performing PID calibration, manual temp setting, and preheat all caused failures). I installed 3.12.2 after seeing a revo update in the description. All the same failures kept occuring. I checked voltages and resistances for PSU, heater block wiring and couldnt find any issues. After reading this thread I reinstalled 3.11.0 firmware and the problem is gone!
Hoping Prusa actually fixes this issue on the next firmware update 🙁
Opublikowany : 04/06/2023 12:30 am
1 ludzie polubili
Abiss
(@abiss)
Sorry to bring this up 7 months later. I am a little illiterate when it comes to coding and things of that nature. Would you mind explaining how to send these codes to the printer like I am a child? Also the steps regarding PID. Thank you.
Also, is this possible to do without Octoprint as I don't have a Raspberry Pi.
Just upgraded to Revo and any information I can find is written in a way that assumes advanced coding knowledge for the reader. Thank you.
Opublikowany : 12/10/2023 9:32 pm
Hello
(@hello)
Posted by: @abiss
Download pronterface and connect printer via usb and connect pronterface then in the command line of pronterface enter M310 S0 then M500 do this every firmware update
Opublikowany : 13/10/2023 3:38 am
Abiss
(@abiss)
Thank you. I did this but there was no confirmation and nothing seemed to change in the printer. I haven't been able to print anything yet because of a separate issue. I assume the only way to know if it worked is by trying to print something and if there is no TM error, that means the GCode worked?
Opublikowany : 13/10/2023 7:14 pm
Hello
(@hello)
Posted by: @abiss
Yep or Even easier just preheat it to 215 if it heats up them it's done the job
Opublikowany : 13/10/2023 8:00 pm
1 ludzie polubili
Platon Avdeev
(@platon-avdeev)
In OctoPrint, you can use G-code scripts to initialize your printer. You might try adding the following line to your G-code initialization script to disable Thermal Model Protection:
Copy code
M310
S0 After adding this line, make sure to test whether the annoying prompt ftp on mac terminal still appears.
Opublikowany : 19/10/2023 8:07 am
Platon Avdeev
(@platon-avdeev)
Posted by: @platon-avdeev
Copy code
M310
This sequence of commands should disable the thermal model ftp on mac terminal protection and save the settings to persist across reboots.
Opublikowany : 23/10/2023 11:47 am
Sheldon McGee
(@sheldon-mcgee)
I started to have this issue with a new release of the firmware a few months ago. I had a few other printers so this one just sat for a bit. Everyone says to use "Pronterface" but it's a scary thing to download and use and it's overly complicated. All you need is a serial interface. I used the one from the Arduino IDE and it's fantastic after change the baud to 115200 and using the right port. The "rescan" for ports is nice too. And you can see the output of what's going on. It's fantastic!
For whatever reason when I used a specific port on a dongle on a mac, the port would not show up but switching too another physical port and it was there. After that I'm just taking advice from the first post. We'll see how it goes!
Opublikowany : 25/01/2025 8:11 pm
Escrich
(@escrich)
Almost every terminal program is able to do the work, as you correctly described
Posted by: @sheldon-mcgee
Opublikowany : 08/09/2025 9:38 pm
1 ludzie polubili
