Hotend Thermal Runaway after following heatbreak replacement guide.
Brad B
(@brad-b)
I replaced the heatbreak in my MK3S with a "Genuine E3D V6 Heat Break (1.75mm) V6-175-BREAK" today after reading about the common retraction failures/bulbing of the custom Prusa heat break.
I haven't had an issue with clogging yet but I'm having issue maintaining 215C when the fan comes on after the first layer. It will hover right around 12-15 degrees below the setpoint until the "THERMAL RUNAWAY" error is thrown and the print stops.
I did a PID tune which may have helped some but I was watching the unit closely and it's still hovering in the danger zone when the fan is at full speed.
I for example did a Calicat print earlier and it failed after the 1st layer. I switched to Advanced more in PrusaSlicer and turned max fan speed to 80% and it completed no problem.
On my current test cube print that is going I watched the thing unable to maintain 215 so I turned the fan speed from 255 to 200 on the LCD screen and it is now maintaining temperature fine.
I've ordered a new thermistor (only $10 thankfully) just in case, but I'm not sure if it's really a thermistor problem.
Is it heat break related? I believe I followed Prusa's instructions on heat break replacement correctly. I didn't use the exact thermal compound they listed (I used Arctic MX-4).
My temperatures seem to stay within +/- a degree just by decreasing fan speed, but I don't see anything different about fan configuration. It's not like you can place the blower motor backwards and you never remove the hotend fan.
This topic was modified 5 years ago by Brad B
Posted : 05/01/2021 4:07 am
Brad B
(@brad-b)
RE: Hotend Thermal Runaway after following heatbreak replacement guide.
It appears to struggle to maintain 215C until 2mm off the Z-axis. Is this normal?
Posted : 05/01/2021 5:25 am
@brad-b-2
Hi Brad, this is unusual behaviour.
can you please let us see pictures of your Pinda Probe, hot end and 'part fan shroud' area from the left, right and front please?
Posted : 05/01/2021 12:25 pm
I'd check the alignment of the part cooling fan duct to make sure it's not blasting the heat block instead of the nozzle area. Consider adding a silicone sock to insulate the block from the fan airflow.
Posted : 05/01/2021 2:54 pm
towlerg
(@towlerg)
Do Prusa and E3D v6 use the same thermistor?
Posted : 05/01/2021 3:47 pm
@towlerg
the thermistor capsule is the same for e3dv6 from e3d and Prusa, but e3d printers have a connector in the wiring near the extruder, whilst Prusa have an insulated joint in the same place!
It's a 100K Semitec Capsule NTC thermistor
Posted : 05/01/2021 8:02 pm
Brad B
(@brad-b)
Here's some photos.
Posted : 05/01/2021 9:23 pm
Brad B
(@brad-b)
Posted : 05/01/2021 11:26 pm
@brad-b-2
In the Bottom picture, the thermistor leads seem to go under the heater. this leaves then more exposed to a Blob of doom than if they go over the top of the heater wires.
that won't cause a thermal runaway
I don't see anything obvious
Posted : 05/01/2021 11:37 pm
towlerg
(@towlerg)
Particularly in the first and second pictures, it seems that the part fan is blowing directly onto the heater block?
Posted : 06/01/2021 10:07 am
